Two on Tour
- Sep 16, 2016
- 10,327
- 50,952
- Elddis Autoquest 175
- Since 2010
For Sale: Fiat Ducato Maxi LWB 2.8 Litre JTD PVC Campervan
Registered 2004 – 54 Plate
Mileage: 68286 Miles
MOT’d until June 2018 but will get it MOT’d so it has a 12 month ticket from date of sale.
Full service carried out in Sept 2017 including a new set of tyres all round. We have done around 2,000 miles since. Van has also recently had new brake discs and disc pads fitted.
Fitted with blue spark tuning box.
Toad Ai606T2 Thatcham approved alarm.
9” Monitor connected to rear view and reversing camera and a side camera for ease of viewing foreign junctions.
Handbrake extension.
Remis cab blinds.
Curtains dividing cab from habitation area.
Front passenger seat swivels round to face rear and has a security box fitted underneath.
Larder storage with tambour door above cutlery drawer and 3 way Fridge Freezer with thermostatically controlled vent fans to improve cooling in hot climates.
Truma 10 litre hot water boiler, gas & 240v below double drawer unit with slide out additional work surface.
High level cupboards all round and low level cupboards below the sink.
Thetford Argent sink with glass lid and integral drainer, next to Thetford Caprice 4 burner hob, with separate oven and grill. There is a pop up work surface to the side of the sink.
Washroom with Thetford cassette toilet, sink, shower and bathroom cabinet.
The washroom is also fitted with a pull out washing line and a Fiamma turbo fan roof vent.
The U shaped rear lounge converts into large bed for 2 to sleep with large storage areas below the seating. Above the seating area is a large Remis tilt and slide roof vent.
The windows in the habitation area are fitted with Millenco window alarms.
The table for the lounge area can also be used outside the van when fitted with the Fiamma legs supplied.
Within the lounge area there is a 16” Cello combined TV/DVD also fitted is an aerial signal booster and a satellite box which are wired to an external aerial point.
Under one side of the lounge seating there is a 1000 watt pure sinewave Invertor connected to dedicated 3 pin socket and a large 180 Ah leisure battery which is also connected to a battery monitor.
Heating is via a Truma gas heater with outlets in the habitation area and washroom.
Propane gas is provided via a 11 Kg Gasit refillable system and this also supplies the external BBQ outlet.
60Ltr fresh water tank and 40Ltr grey tank.
All interior lighting is LED and in the washroom there is a red LED light so as not to disturb your partner at night with a bright light.
There is wood effect laminate flooring in the habitation area.
Fitted externally it has a removable roof rack and top box which is accessed via a fitted ladder, this too is removable
It has a 3 meter wind out Fiamma F45 awning.
It also has a Thurle electric slide out step.
Beneath the vehicle are fitted 2 storage tubes that we used for storing toilet and engine fluids and the like.
Rear and side lights are LED to reduce battery drain if the lights are required to be left on when parked.
It is also fitted with a Tow Bar and rear spring assisters.
You get all this for £15,000.00
Please PM me if you want any more details or information and to arrange a viewing.
We are in the Huntingdon area on the A14 and close to the A1.
Remis cab blinds.
