fiat ducato 2lt petrol 1996 want start
W
william wason
hi. have fiat ducato 2lt petrol 1996 want start just engine turns over , have petrol to injectors , spark to plugs and air ok , cleaned injectors and checked compression have changed
1. fuel filter , spark plugs , HT leads , lambda sensor , ignition coil pack , butterfly sensor , air intake sensor , air filter
so was thinking cam and crankshaft sensors maybe problem as getting spark , petrol and air . do get occasional backfire
dont have OBD socket on motorhome so change parts and see just now , any help would be appreciated
please only serious comments not run it down hill in gear answers
take care
william
W
william wason
hi. would start first time every time then after changing LAMBDA sensor for a previous problem started every day for 4 days then 5th day would just turn over unpluged LAMBDA sensor to see if that was the problem but just the same
W
william wason
hi. sorry last time started about 4 weeks ago
Jun 17, 2012
2,692
8,214
North Essex
Autotrail Delaware
>8 but <9
How old is the petrol?
Does it spin over quickly? If so does it puff back through inlet?
Is cam turning?
W
william wason
petrol 8 weeks old
4 weeks since last run
dosent spin fast as if cylinder head gasket leaking as done compression test and all ok
cam shaft is turning ( engine only done 54,000 )
W
william wason
taken fuel pipe off fuel injector rail and put in bottle switched fuel pump on 5 seconds bottle half full no water
i stay central scotland
W
william wason
should go if spark there but if spark getting wrong signal from faulty cam or crankshaft sensor spark is not going to correct cylinder , thats what i am thinking
Nov 18, 2011
10,809
29,975
OK have you checked your throtal body and associated cabals and wiring check for broken or perished wiring
bill
Nov 18, 2011
10,809
29,975
check that sensors are clean thaye can get fillings crap build up and stop them working run a feeler gauge between the gaps
bill
W
william wason
cleaned throtal body , butterfly but would take forever to check all connections
thanks for trying to help but think its time for AUTO electrician
if it had OBD socket 10 minutes part shown but not there
W
william wason
hi. think so as well cheers
Feb 16, 2017
333
394
Southampton
Mazda bongo
Newbie
Hi mines a 1999 with a xu10 engine that had a starting or running problem they turned out to be the pressure switch on the fuel rail. I took it off cleaned it out and it's all ok now. When you start the engine the switch supplies extra petrol then clicks back to normal running mode maybe yours is stuck in the running mode and not getting the extra squirt to start? PS I later found an OBD port up behind the air filter on the near side but I've never used it.
W
william wason
hi. yes have seen that switch and thought it was a pressure relief switch in case fuel pump went faulty and kept putting pressure in , i have a black tube coming off that going to no where and thought ( looks very twisty lol to be just a bleed off tube for petrol and spraying over engine ) next to it looks as if pipe should go there but this has a black rubber plug over it
getting petrol to pugs as after turning key plugs are wet
will look for OSB port if i find it there your a god send as will put my computer on and maybe find problem
Feb 16, 2017
333
394
Southampton
Mazda bongo
Newbie
Just read your post above, the pipe you mention should be connected to something mine is I think it works on vacuum . I'll have a look in the morning. The OBD port is right up by the corner of the windscreen, one grey socket and one Small green one just hanging about in the cobwebs
W
william wason
hi. thought it was a vacuum pipe but never taken it off anywhere , thanks will check for OBD port
Nov 16, 2017
48
85
Worksop
Chausson 711
28 Months
Hi try a bit of easy start down the inlet manifold, if the engine fires you then will know the ignition is ok and concentrate on the fuel side. You could also squirt a bit of engine oil into the cylinders incase it has bore wash to help get the compression up.
Keep it simple first
Jan 28, 2008
8,381
12,730
walthamstow east london
renault burstner delphin
7 years campers before that
Carb cleaner or easy start in the intake will decide if it's spark or fuel that's the problem
Jun 17, 2012
2,692
8,214
North Essex
Autotrail Delaware
>8 but <9
Got a sluggish diesel on a dying battery to fire up with deodorant (not roll on !) can use hair spray if nothing else. Brake cleaner is also very volatile but resist using too much, get someone to crank while you spray as close to throttle body as possible.
W
william wason
looking for wiring diagram for FIAT DUCATO 14 MWB 1996 2lt petrol to find out where the ignition coil sensors are ( cam shaft and crankshaft ) and if any body knows if engine immobiliser cuts the petrol and spark off to engine , cranks over but want start
