Fiat Ducato 2008 Mobilvetta positive terminal (1 Viewer)
PJSIMOES
3
RH Hi Top
Since 2001
Is there anyone that can show me in a photo the positive terminal, so that I can charge the battery?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,582
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Cant be done without a certain amount of risk because your vehicle may have
had a modification or battery changed that you or any one else is unaware of
99% of battery's have either a red ring marking the poss or a + sign close to the terminal.
it may be cast into the case and be difficult to see as it will be most likely be black but it should be there the negative is marked with a minus sign -
Lenny HB
50,292
138,949
On the coast in West Sussex
Hymer B678 DL
There is a jump terminal under the bonnet beside the fuse box it has a black plastic cover on it
Reactions: DBK
DBK
17,915
47,672
Plympton, Devon
PVC, Murvi Morocco
If you open the bonnet the terminals for jump starting and charging should be on the right and sort of behind the headlight. Well, that's where they are in our 2013 van. They are very easy to spot.
PJSIMOES
PJSIMOES
3
RH Hi Top
Since 2001
Thanks for the response!
I'm gona try to locate the jump terminal
