I need to know if I can disconnect the engine battery terminals on our 2015 fiat based MH without causing a mass of problems. To be specific can anyone advise if a) the battery be disconnected without causing a mass of problems need resetting of this that and the other, and b) if it can what should be disconnected / switched off prior to so doing? For the moment I would just like to check the battery fluid levels but can't do so because various bits including connectors and terminals are in the way.
Thanks in advance for your help.
