Saltings
Cheers Berni
I have the wires that you mention that terminate in a yellow plug that appears from beneath the floor. The part that clips into this is attached to the seat beneath the seat belt tensioner (leading to a compressed air cylinder that is in the side of the chair beneath the arm rest.)
The wire that I cannot find a home for is just a single wire that I remember screwed into the base of the part U sit on and is earthed on the seat framework next to the hand brake.
I have added a couple of pics below. No problem with the twin wires attached to the seat base, problem is where does the earth wire attach to the seat?
They both then drop through the large hole in the base plate! That bit I remember...!!
