Fiamma type island table (1 Viewer)
4
42208
Hi, I am in the process of replacing my van and I have seen one that has a table on a single post, looks very much like
http://www.rainbow-conversions.co.uk/bases-legs/fiamma-island-leg-set-1131-p.html
Those who also have such a table I was wondering do you travel with the table up or is it necessary to put this type of table away when travelling. My previous van had a single leg one side with the far side of the table attached to the van wall and was fine for travelling, however, not sure about the effect of 'swaying' forces on a single post table. Any experiences welcomed.
treetops1
1,599
1,759
yorkshire/ lincolnshire.
Sold last van-
a long time,since 1996
If the post is fastened to the floor and the table top is fitted to the top of the post correctly you should have no problem ,plenty of vans have them .Enjoy lol .
Apr 29, 2009
1,189
717
West Sussex
Burstner Nexxo T740
since 2008
We had one in our Van Conversion and travelled with it up - never gave a thought about it being dangerous (until now) We have removed the table in our current M/H and use a table with a single leg on a tripod that does for both inside and out. However that is stowed away for travelling,
Two on Tour
9,722
45,342
Elddis Autoquest 175
Since 2010
We had one in our PVC and travelled with it both in the up position and stowed away with no problems.
The post is tapered both ends and fits snugly into both the floor fitting and the table top and if anything it was a struggle parting them apart on occasions. The posts are available in different lengths so be sure to get one the right length or you will be resting your chin on the table or having to get longer arms to reach it.
We also had the tripod legs so you could use the table outside as well.
http://www.rainbow-conversions.co.uk/bases-legs/fiamma-tripod-table-stand.html
42208
Put it away! You wouldn't want it flying past your heads if you made an emergency stop....
Clearly don't want to ignore good advice, have many members experienced this?
42208
Thanks, looking forward to getting back out in the van, old one sold before I bought the new one, wont do that again!
42208
Had a look at the tripod, looks a great solution for outside and save carrying an extra table, thanks
thebriars
1,149
2,182
Teesside
Since 1990
We all must have. Ever had to brake hard in a car and hear everything in the boot slide forward, or things slide off the seat?
Far worse would happen in an accident if you come to a sudden stop because then everything not well secured will come flying forward.
42208
The table comes with the van so I will have to wait and see how it fits for size and order a different length if unsuitable
42208
Agree and guess that was my point in asking the question ie how secure are they when travelling which on occasions mean stopping suddenly, my last table (standard dinette type) stayed exactly where it was when braking hard, I was just wondering how robust others had found theirs and their general experience with them
denisejoe
5,395
11,320
Warden isle of sheppy
Since 2004
We can't remove ours. It is screwed firmly into the floor and firmly screwed to the underside of the table.
Denise
Jan 28, 2008
9,945
17,623
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
there was a post on a self build group which showed the table not being very stable the newer one have a plastic end that wobbles
thebriars
1,149
2,182
Teesside
Since 1990
I bought one recently for our van together with a table top and the tripod legs. The ends of the leg are plastic and there is now only one size. Fiamma supply it with the plastic ends loose and give you 4 screws. Once you have cut the leg to the right length you have to screw the plastic ends on. The screws go into the aluminium extrusion which is the round post and they are very difficult to screw up tightly. I suspect some don't get them tight and this is why the leg wobbles.
My table is quite secure, but it travels in one of the wardrobes with the fittings I made and bought:
The bottom of the post is secured in this wooden bracket. Its painted to match the wood finish. The bottom of the tripod leg is also secured in a wooden block.
42208
Thanks for the pics, very neat and tidy job you've done there
42208
IVE GOT A POLE AND TABLE SECTION IM TAKING TO THE BRING AND BUY WHERE ARE YOU?
Thanks for the offer, however, the van already has a table I just haven't picked it up yet and was simply wondering whether members stowed it away for every journey or left it in situ.
