Falcon 269
Hi all,
We have a 4-year old Fiamma Turbo Vent 160 fan in our moho which is giving problems. It shuts down after about 3-4 mins operation on full power. The thermo cut-out on the circuit board gets hot and I suspect that it shuts down to avoid damage. Once cooled off, it will run again but the symptoms repeat.
The motor is supposed to draw 3 amps at max power but the control board in our vehicle shows 6.6 amps draw. The motor rpm occasionally fluctuates and these two factors together lead me to suspect the motor is at fault.
There's no visible heat damage to the circuit board but I haven't the kit or skills to do any further diagnostics on the components. I can say that the fan doesn't run any faster on max than it did when new. This might rule out a problem with voltage/current control through the board but that's just speculation on my part.
Before I go ahead and order a new motor, any advice or previous experience with these fans that you could share would be much appreciated.
Mike
Mike
