I've never removed one, but looking at the design and what appears to be mounting brackets on the rear, I'd say it lifts up and off. Maybe a gentle tap upwards with the palm of your hand should see it moved.
Take the silver top off, push back the plastic tang at the back and slide the container upwards and off. You'll be left with the plastic mounting frame, which might be glued or screwed on to the wall.
To take off the top you need a little plastic 'key' which should have come with it, but you can just use a small flat screwdriver instead - there's a small 'screw' on the top at the rear so use the key/screwdriver to make a quarter turn on it and the top will come off, then press in the tab on the back and it will pull up.
You can see the little plastic key in the below left:
