Hi Folks,
We have a Fiamma Security 31 handle on our habitation door. It will lock when flush against the wall pointing to the rear of the van and lock when at 90 degrees to the van wall. It won't however lock when across the habitation door when the hab door is closed. If I open the hab door and put the Fiamma handle into the position across the hab door opening, the pin clicks in and it locks. The Fiamma handle is right up against the hab door handle which sticks out by enough millimeters to stop the pin locking on the Fiamma Handle.
I have tried moving the hab door locking pins on the door frame slightly more into the van to bring the hab door into the frame and lubricated the lock but it won't sit flush enough pointing forward to allow the pin to lock so I cannot lock it with the key.
It's a factory fit on a 2010 vehicle and I cannot believe it has never locked. Does anyone have any other suggestions? Is there any rotational adjustment within the locking barrel to allow the pin to lock in a position slightly (in mm) out from the van? I've considered additional rubber pads on the van wall and handle point to move it out but am concerned about water ingress. Unfortunately I don't have what looks like a Torx tool to take the handle off.
Could the hab door actually be bent?
