Checkingout
Hi all, looking for some guidance from you skilled and intelligent funsters.
We have a 7 l/min Fiamma isensor aqua 8 water pump with a Truma Combi 4 E water heater system and a frost protection type pressure relief valve.
Our problem usually happens after we have switched on the water heating and the water has heated up fully whereby randomly the pressure relief valve opens and dumps water out the drain valve, the pump runs for a couple of seconds and stops, then the prv opens and dumps again, the pump starts........ this just keeps pulsing like this wasting our water. Sometimes this stops by itself after a few cycles, sometimes we can stop it by rapidly opening and closing a tap, sometimes we have to turn the pump off at the controller. Frequently when we use a tap, the pressure dumping/pump running cycle starts up but often it just does it by itself.
I understand that when you heat up water in a closed circuit, the pressure will rise and the prv should quite rightly open to relieve that pressure, however, something here is out of balance. Either the pump is delivering pressure above the prv setting (I don't think this can be adjusted on the isensor Aqua 8) or the prv is set too low or is not closing off fast enough after relieving pressure leading to the pump having to start up? I don't know why it should be so much worse once the water has heated up? We had a slightly different problem a few months ago and had a new prv installed. It has been fine until the last week or when this problem started and is getting worse.
It should still be covered by warranty but we are in Greece right now and about to head to Turkey and I'm not sure I can find someone to repair this.
Any cunning plans for me to try or have others had this experience.
