SNAP broke ours a few weeks ago in Spain. The handle has snapped where they have cut the grove for the small handle retaining clip. Put mine over my knee and bent the end over at 45 degrees so I could use it and then bought a non extending one.
The simple non extending one is far stronger than the extendable one. The extendable one certainly has a design fault.
I'm confused! The extending one is much more robust than the non-extending one as it doesn't have the silly joints, this is the extending one which is what we use with a large awning without a problem:I'm going to go with the non extendable one as think I'm going to get the same problem again as the amount of pressure on the joint trying to unwind a 4.5mtr roof awning is quite considerable
Check out C&A plastics Gillingham, I have a feeling they sell them for their conservatory roof windows and cheaper. They might have a brochure on line. Can't be much more help as away in Holland.
You do know that that part is supposed to be loose don't you so the bar inside can rotate ... how on earth did you break it?I've now glued mine together with gorilla glue and it's holding at the mo. And I plan to bolt the two bits together when I'm back home View attachment 170457
