Fiamma Bike Rack Pro (1 Viewer)
Justamil
51
51
Worcestershire
Low line Coachbuilt
30 years
Fiamma Bike Rack Pro. (edit)
2 Bike.
Used.
Fixing centres when new were 80cm to 150cm.
This one has been used and cut down and will now only fit 80cm to 131cm.
Presently set up to 91cm.
All mounting bits present plus instructions.
Price £50 if collected at Malvern Motorhome show.
3,610
7,833
Aberdeenshire
B524
2nd base
Sorry can you explain what you mean with the differing dimensions you have given? I took a broken Fiamma bike rack off my van and I am looking for something similar that will fit the existing clips etc
xgx
100
60
North Cambs/South Lincs
umptynine years
...and I'd be interested in the fittings if you consider splitting ;)
J
Justamil
51
51
Worcestershire
Low line Coachbuilt
30 years
Monser,
The two sides of the rack are spaced at 60cm apart, however the distance between the top and bottom fixings can vary between 80cm and 131cm on this rack. It is set at the moment at 91cm.
You choose the distance to fit your existing fixings. You need to drill two new holes in the top vertical poles (the vertical uprights consist of two poles which slide, one inside the other, to vary the distance).
To be honest It’s difficult to explain. The manual has pictures, much easier. Download one off the Internet, that would explain it better.
Paul
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
That rack looks long thought the pro c was a lot shorter rack it generally fits below rear window
J
Justamil
51
51
Worcestershire
Low line Coachbuilt
30 years
Mfw.
You’re absolutely correct. It is indeed a PRO and not a PRO C!
The confusion comes about because I somehow have the Pro C instructions and not the Pro instructions. I just looked at the instructions for the name which you can just see in the one photo of the bag of fittings. I do have the correct instruction book on the computer where I found the diemensions. Thank you for pointing that out.
Paul
