fiamma awning (1 Viewer)
Apr 28, 2008
157
30
rayleigh, essex.
I have a problem with the wind out awning on the van in as much that when i use the strap across the awning when windy it pulls the legs down i have tightened the lock nut as tight as i can by hand and it appears that it is metal to metal contact has anyone had this problem and was there a way to cure the problem.
Thanks Chas.
Steve N Tracy
1,229
3,722
Southampton
4 Years
If its doing that then maybe its to windy too have the awning out! never had a problem with the awning legs collapsing using the Fiamma straps that clip in the front rail and that was in 50 mph gusts admittedly from behind the van.
Clickem
1,034
1,073
Northumberland
None
7 years
I have found a similar problem and assumed that I was probably over tightening the storm straps. I had considered drilling a small hole through the leg and fitting an R clip
Nov 4, 2011
5,920
38,676
Uk
I cut a couple of washers out of a plastic milk carton and that helps the grip.
Huwmari
253
183
Cornwall
Benimar Mileo 201
since Apr 2013
I think you are risking damage to your awning. If it's at all windy we just wind ours in. Better safe than sorry .....
Oct 29, 2012
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
a was told never to put a strap across the awning as it can slice the material, much better to use the fiamma system that clips to the front rail with two separate straps (like steve n tracy)
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
For that very reason, I use the storm strap over the top of the side arms, but under the fabric.
Also got the Fiamma straps for the front rail, but rarely use them.
chasthedagger
Apr 28, 2008
157
30
rayleigh, essex.
I should have said the awning is the zip type and has the full awning fitted to it so the extra weight and the strap plus a bit of wind is the reason the legs dont stay up as they should.
