- Oct 29, 2016
- 4,469
- 51,766
- Carthago C Tourer
- Motor Homing 5 years, caravan previously
First one should be easy when you know the answer....how do I remove the outside Top & Bottom Dometic FF vent covers? cant see any screws dont want to break them in this cold weather.
Second: what is going on with the interior light switching arrangement in our van, its either all on or all off in some cases!!! There are two way switching, and even an intermediate switch that turns all lounge lights on or off! They are also too bright, I counted 15 LED lights in the front lounge alone, so so hoping that I can fit a master dimmer switch to replace the intermediate one so as to set a more pleasing lighting level...is that a good idea?
Carthago is renowned for its quality cabinets, which I agree are pretty good, except for the curved under sink ones that is. First trip out from dealership, going around a roundabout the bottom one flew out, came of its underside runners, the cupboard was empty. Couldn't work out how to get it back on the runners with those funny looking black clips on the underside of the draw itself. I thought sod it, the dealer can sort this out which I thought they had done, but no it hasnt gone back properly, and now binds when pushed in. I had a go at pulling both runners out to fully extended and lifting the draw unit back in and pushing down to relocate the clips on the runners but, it wont slide in smoothly and has come off again, so abandoned using that drawer altogether.
Any suggestions on how to fix this problem would be great. I will probably have to take out all the drawers in the near future anyway to run gas pipe for BBQ and solar wiring etc, not looking forward to getting them back in though.
Hoping that I can get some additional 12 volt & USB sockets at the Peterborough show, along with some other electrical bits. I will do the Solar panels and controller wiring late in the year, if it ever stops raining that is.
Thanks for any help you can give on the above.
Les
Les
