barracudabus
Since we purchased the van we've never had pumped water and now it's time to get it sorted. Here's what I know / don't know:
- There's definitely water in the cold water tank, I don't know how to tell whether there is water in the hot water tank, and haven't yet braved heating it just in case it is dry and I damage it.
- Whenever I turn on any taps I get a dribble to start and I can hear the motor briefly for 5 - 6 seconds and then the motor starts pulsing on and off (but within acceptable guidelines of the manual) so on for a couple of seconds - off for a couple of seconds. But at this point the dribble becomes more of a drip.
- If I turn on both the bathroom and kitchen sinks I get a more continuous motor and "better" pressure but not what I would expect
- When I first switch on the pump on the control unit there is NO pump noise or action (light is on). I would have expected to hear it priming. Right?
- I have cleaned the filter on the pump inlet
- If I open the dump valve I get continuous pump action and the water appears to drain.
So I believe (rightly or wrongly):
- The pump isn't broken, else it wouldn't work when operating the dump valve
- It MAY be an issue of air lock or needing a prime
I plan on going into the van today to have a look and see what I can do but would appreciate any pointers, advise or even warnings if in fact I'm incorrect and there is another path I should be travelling down.
TIA
TIA
