Chris CM
My 2015 Ducato 150 has developed a fault with the rear fog light warning light on the dashboard, it no longer illuminates when the fog lights are switched on. Unfortunately this is not a simple switch but, I have been told, communicates with the Body Control Module. Has anyone else had this problem? And if so how did you fix it? It has been suggested that I run a wire back from the light cluster to the dash and install a warning light. Not a bad idea but it would be easier if I could get a feed from behind the dashboard. So any ideas/views gratefully received
Thanks.
Thanks.
