Fablon edges needs resticking
Sherborne,Dorset
Swift Sundance 580PR
3yrs
Need some advice , around some of our lockers etc , fablon seems to have curled away
Tried Stixall , but that doesn’t seem to make the edges hold, just trying to wipe a little bit
Under the edges and sponge off, I suppose just looking for something to fill time , regards Martin
if it is just starting to come away I would use PVA applied with a small brush, and masking tape to hold it in place till set
Evo stick is what you need. Apply thin coat to both surfaces and allow to go dry to touch then stick together. (y)
Spray adhesive works, just done a small piece in my van. If it’s a small area then spray the glue into the lid and paste both surfaces with a small brush then leave it for a few minutes.
I agree -- I have had good results with Evo-Stik Timebond re-attaching trim on cabinets. To be sure, I generally also secure the glued piece with tape and then remove the tape after 24 hours.
