External shower (1 Viewer)
octopush
147
54
portsmouth
2days
I want to fit a external shower to my autocruse starblazer 04.
Could anyone tell me if the pump works from pressure relief or is it triggered from a micro switch when the tap is turned on.
Thanks Rob
2,322
10,016
don't know.. but a quick look under the sink will reveal all..
wires to taps... micro switch operation..
no wires.. pressure operated..
11,953
16,570
Thanks Rob
If it runs on briefly after the tap is closed you have a pressure system.
2,322
10,016
Just had a thought..
Do you know if it's a submersible or a Shurflo type that is mounted outside the tank ?
Submersible pump will usually be controlled by a micro switch on each tap , although that's not always the case, as they can also be controlled with an in-line pressure switch..
Shurflo type are controlled by a pressure switch on the pump body.
octopush
octopush
147
54
portsmouth
2days
The pump dose run on after the tap is closed for a few seconds.
The pump is outside the tank.
Thank you all for your help it looks like i have a pressurised system.
Makes fitting a external shower a lot easer as i will not have to run a switch to it
