Steve and Denise
Well I think I have found a solution flexible drip rail comes in grey or white and is self adhesive.
The company I bought it from are Rainbow conversions Algors way Wisbech you can buy it by the meter about ÂŁ10May I ask where you bought that from please.
Many thanks.
Already tried the one on the roof without success a couple of weeks ago so I have put this on the window frame.Are you going to fit it on the roof like the one Hymer fit above the drivers door or on the side above the window?
I'm never that lucky @JockandRita the only thing I get for free are colds
Yes there is a length on the near side roof I did copy on the off side but still had loads of water like a small river just under the roof seam.Steve, is there a length of rail already fitted over the passenger door side on the roof push the water over the front? That causes water to push over to the drivers side on mine.
Ps You missed out on a week at Seaburn Camp, endless sun, sea and sand!
I've had 3 Hymers never seen that.I thought hymers came with gutters all along, down both sides, ours certainly did.
My Radio could do with that for when I reverse out of my drive after heavy rain with the sliding window open so I can hear my banksman/wife. One time a surge of water from the roof hit me through the window!
Ours does as well Paul.I thought hymers came with gutters all along, down both sides, ours certainly did.
Yep.Must be the older ones then, will post a pic later this evening when I am not on this tablet.
Mine has raised joints along the sides, I wondered what they were for. They run from to pof front wheel arch right up to roof side joint and all way down to rear bumper. Stick out about 20mm channel shaped.
Hyner B544 '62
O
Yep.
Cheers,
Jock.
Know what you mean now.
That's how the joints were on the older ones an aluminium jointing rail I think they changed to the plastic joint 2006/7 when the Almond eyes front end came out.
Correct, it is a problem on N+B vans as well, I did try the Fiamma stick on stuff and for starters the channel can not handle the amount of water that come down when you move the van and secondly the ends curl up and it looks rubbish, thats why our van has a custom made fibreglass channel coming from the roof and down the front on the side windows, it works well and the added advantage is that it takes all the windscreen water up to roof level instead of the side windows.Yes thanks Jock, I thought I was going crackers there for a while, that seems like a backward step not using the gutters now. I know all N+B vans have never had gutters, I have seen loads of cheap stick on gutters above driver and passenger side windows and garage doors where the water just floods off because no gutters.
To be honest I think that the factory should have added better rain water management as standard but at least it gave me something to make.
Martin
