Alistair33
Is there such a thing as a single toll tag that will work in all / most European countires?
The same question again regarding access to cities from a polluting point of view. Will one pass cover all countries, I fear the answer may well be the same !
You would have thought that there'd be an EU-wide sticker/tag that could be applied by manufacturers or converters indicating the Euro classification of the engine, which could be integrated into pollution control systems. However that would be too much like common sense.
There are height detectors as you go through!Do you know for sure you will be detected as class 3?
Never mind what your MH actually weighs or whether it technically should be class 3 or not. In practice things work slightly differently. Unless you're over 3m high by a margin the chances are you will be detected as Class 2 in France in which case that device is no good for you or if it does work will be a bloody expensive way of doing things.
If you are as you say "way over 3500kg" you are also way over class2, if you are using a Sanef/liberT tag I would imagine that you accepted their terms and conditions when you applied tor the tag and one of those conditions would be that you were only going to use in in a vehicle less than 3500kg and less than 3 metres, therefore when you present this type of tag at a toll booth the default position is Class2 as per the terms and conditions, likewise the Telepass system is Class3 or Class4 and NOT to be used on vehicles less than 3500kg.Yes I know there are. That's why I specified weight and said unless you're over 3m.
We're way over 3500kg but well under 3m high and have always been detected as Class 2.
Me, I just stay off toll roads.
Martin
Interesting, I wonder if you fitted a Telepass Class3 tag would you be rejected and have to manually pay Class2.I sometimes take the tag down so there's no chance of it registering and go through a manned booth to see what it detects me as. Always Class 2. If I then show the tag I'm just waved forward until I reach the tag sensors.
I can't be bothered to go through this all again because it bores me. I'll just do the short version.
When you drive up to a toll the system detects what class it is going to charge you before it registers anything else. The tag sensors are further forward, almost at the barriers. If I'm ever detected as Class 3 the tag won't work.
If I was ever travelling a van the size of yours or a big HGV and put the tag in the windscreen it wouldn't work.
So don't go through it and bore yourself, and just accept that you manage to achieve life changing financial benefits others are simply unable, or frankly cannot be bothered to achieve.I sometimes take the tag down so there's no chance of it registering and go through a manned booth to see what it detects me as. Always Class 2. If I then show the tag I'm just waved forward until I reach the tag sensors.
Martin
