Eura Mobil Xtura 4x4 Chat
Interesting… Rhino did my VB. I’ll see if I can them to uprate the MLt to 4700kg.
Steve initially pointed me to SV. VB did all the work but it came through Rhino - and I paid them. Either way, start with the form I linked to.
4.4 vs 4.7 and the front/rear balance came down to wheels and tyres. John and Jo had the certs for our wheels which I had to send in addition to the photos. That got us to 4.7
Also, unlike SV’s service I had to fill in the V5C myself but, it’s very simple.
Looks like we may need to have it redone ….
Do you have the Delta wheels?
I don’t thinkVB will supply their kits to unauthorised dealers/fitters so I think you’ll be fine.
Filling the form in on VB’s site is free and a simple check :-) you don’t need the V5C to start the process (I think)
Yes Delta Wheels. Thanks!
My wheels are the Rhino Atlas green....
I bought them because I liked the wee white rhino logo, the Atlas mountains for Morocco and they were green & black to match the van
Thats how technically I go into choosing stuff for my far flung trips! 🤣
The Rhino wheels are (I think) rated at 1134kg the Xtura Deltas are 1360kg so I think they will be a problem if you need the extra weight on the rear (Abgs). The BFGs are also good to 1350kg from memory.
Hi folks,
Does anyone know how the shelves in the cupboards are fixed? I'm assuming they have small dowels either end and are assembled at the factory????
I'd like to remove this shelf, so any opinions would be appreciated.
Steve
Rear Camera power?
Does anyone know if there is a separate positive feed to the rear camera or is it fed via the Mercedes "down pointing" camera, which I assume is hard wired in?
I have the usual issue of camera flicking on and off on the Tread, to the point it is useless. I've put a "test" positive lead to the Garmin transmitter from the leisure side, so it can work without the vehicle on, and the camera works perfectly.
As soon as you start the vehicle, or even just wake it up without starting, the camera issues arise again. So it's looking like a power issue from the vehicle side, I wanted to try things with a leisure supplied positive lead to see what happens.
My down pointing Mercedes camera doesn't work, I'll be taking that for an update at Mercedes (apparently fixes it) but until then, I'm just trying to work things out...
Hi all, has anyone replaced the OEM Xtura table with a Lagun Pedestal? The OEM table top size is good but does get in the way a bit - forever swinging it around to get the best clearance with the rounded side depending on whether moving between the cab or sitting to eat. Thought a Lagun pedestal might ease this.....
On another note, we have had the same rear BC50 camera connectivity issues and seems to cut out on the Tread when we connect our mobiles to our onboard router's wifi. Soon as we switch the mobile phone connection off it seems to work pretty consistently. I am wondering if the BC50 is fighting the other wifi signals around it or maybe it's the interference of the wifi channels each is using? The BC50 seems to be trying to 'gatecrash' on another wifi source other than the Garmin Serv it's supposed to use..... then isn't able to connect and goes back to the correct Garmin signal route....... So I guess, trying to 'handshake' with the wrong wifi, gettiung rejected, or getting interference, and cycling back to the Garmin..... had this with bluetooth connections .... but may be just concidence. Just a theory???????
Interested in any feedback on a Lagun alternative.
Neilfg has done exactly that.
I don’t think anyone has the BC-50 working as designed. 46stm has fixed his by hard powering it which makes me strongly suspect that its power related not interference. We (Jane and me) think it’s not strictly a wifi connection between the bc50 and the tread. It’s still in the same frequency range but it’s not using any wifi network.
My best theory so far is that the Mercedes PSM (canbus interface for converters) provides a noisy signal and the BC50 cycles the network too quickly.
The BC50 is definitely WiFi ours insists on connecting to an open WiFi connection BC50_xxxx. The Tread camera app also wants Bluetooth, but I think this just in case.
I am puzzled why 46stm solution does not work reliably with Tread only with Camper 795.
Just driven 250 miles, the first real BC50 test on the Camper 795, worked faultlessly all the way.
It might work on the Tread for others, but mine didn't, not properly. I'm not even going to bother trying again:
1. The 795 gives a perfect picture in my eyeline. Can also run Sat Nav at same time, shortened version on the top line, not shown in picture.
2. I now think the Tread is excellent, it just simply works perfectly now the camera is unpaired and doesn't lose connection to STX (SERV)
3. I've also paired another BC50 with it as my MBUX doesn't work yet (that's another story) , quick press of the screen and it swaps cameras instantly.... Can also pair two more cameras if I want it to at a later date. Handy as a little CCTV camera too as BC50's all powered from leisure battery, with a switch so I can turn them off.
Simple, uncluttered, and works.
(Pic taken by my wife)
We took out the fixed table, attached a bock of wood to the side of the cupboard where the boiler is located and put a Lagun arm there.
We have changed the top since the photos were taken to one slightly smaller and offset closer to the kitchen side.
It's an easy change and we can put the big table back if required.
Where we have fitted it makes it slightly more awkward for the passenger to put their feet up but as the driver seat user I feel it is a small price to pay 😁
Thanks Neilfg the photos are most helpful along with your feedback .... certainly looks like it free's up the access. Will investigate the space behind the bottom mounting panel for access to put a support plate behind. Do you recall what the matching panel wood grain pattern is for the panel face as it blends in well?
Follow up on the BC50 camera issues that we get, for us it seems the only time that the camera connection drops is when we are underway/driving on the road, all starts up ok, displays and works fine, then if during the drive a mobile phone’s wifi is switched on to connect to the onboard router (linked to internet via Starlink) then the camera connection drops.... sounds different to others experience?
Just did a google search “in eura mobil xtura how is the bc50 connected/wired to display over the tread overland AI Response:
The electrical and data connection breakdown works as follows:
1. The Video Transmission (Wireless Data)
  • Wi-Fi Connection: The BC 50 utilizes a built-in 2.4 GHz Wi-Fi transmitter to stream up to 720p HD footage over the air directly to the Tread Overland display. There is no RCA or video-in cable running from the back of the motorhome to the dashboard.
  • The Transmitter Box: The camera itself is wired to a small Garmin transmitter box (usually hidden in the rear wall, a cabinet, or the top rear brake light housing of the Xtura). This transmitter handles the wireless connection to the Tread display up front.
2. The Power Connection (Physical Wiring)
  • Because the Xtura integrates all on-board electronics into a central Garmin EmpirBus™ system, the physical power wiring depends on how the vehicle is configured from the factory or your preference:
  • Option A (Switched Reverse Power): The camera's transmitter is spliced into the vehicle’s 12V reverse-light circuit. When you shift the Mercedes-Benz chassis into reverse, power is instantly supplied to the camera, which prompts the Tread Overland screen to automatically switch to the backup camera view.
  • Option B (Constant Bus Power via EmpirBus): The transmitter is connected to a 12V constant or accessory circuit managed by the EmpirBus smart digital switching. This configuration allows you to manually open the camera view at any time while driving forward by pressing the Camera app on the Tread display
Then asked a follow up question on the symptoms that we experience: ’ intermittant connection during driving?
AI Response:
It provided a link to Garmin Support Article: https://support.garmin.com/en-US/?faq=BfaBPmtfpj0K0BQ4dRs8u8 – scroll down to About Buffering Video or Intermittent Connections section.
Search result also adds: Experiencing an intermittent connection while driving with the Garmin BC 50 in a Eura Mobil Xtura is common, but frustrating. Because the Xtura is roughly 6.88 metres long and built with dense overland insulation, composite walls, and internal aluminium framing, the 2.4 GHz wireless signal is pushed to its absolute limits.
When the vehicle is in motion, structural flexing, alternator engine noise, and competing wireless frequencies cause the Signal-to-Noise Ratio (SNR) to drop, triggering drops and "No Signal" screens. [1]
The issue can be systematically diagnosed and resolved through the following steps:
1. The 2.4 GHz Wireless "Jammers" (Most Common Cause)
The BC 50 transmits on the 2.4 GHz band, which is incredibly crowded inside an overlanding motorhome. When driving, specific systems can overpower the camera feed:
  • The Cabin Wi-Fi/LTE Hotspot: If the Xtura has an active onboard Wi-Fi router or a mobile hotspot running, it will directly conflict with the camera. Try switching the router off temporarily to see if the dropouts stop.
  • Wireless Apple CarPlay / Android Auto: If a smartphone is connected wirelessly to the Mercedes MBUX dash system or another device, its Wi-Fi direct connection can choke out the Garmin transmitter. Test driving with the phone's Wi-Fi disabled or plugged in via USB.
2. Physical Placement of the Transmitter Box
Many factory or aftermarket installations mount the actual Garmin transmitter box right next to the camera body on the upper rear panel.
  • The Problem: The signal has to pass through the entire length of the Xtura's living pod, bathroom walls, and overhead cabinets to reach the dashboard.
  • The Fix: The actual camera lens is on a wire that unplugs from the transmitter box. If accessible, relocate the transmitter box further forward inside the motorhome (e.g., inside a forward overhead locker or closer to a window panel). Minimising the amount of dense metal or insulation between the transmitter and the Tread screen drastically stabilizes the stream.
3. Garmin Tread Placement in the Cockpit
Moving your Garmin Tread Overland screen just a few centimetres can drastically change signal reception. [1]
  • Try repositioning the Tread on your windscreen mount or dashboard.
  • Ensure it isn’t buried deep under the overhanging dashboard or placed directly against the Mercedes Sprinter’s structural metal A-pillars, which shield the antenna
4. Check the "Signal Strength" Tool
To see exactly how bad the connection is before tearing into any wiring:
  1. Turn on the vehicle so the camera live feeds.
  2. Go to Settings > Wireless Camera > BC50 on your Tread.
  3. Check the signal bars. Garmin requires 3 to 4 solid bars for smooth video while driving. If it sits at 1 or 2 bars while parked, it will consistently drop out when you start driving and engine noise/vibrations are introduced.
5. Alternator Voltage Fluctuations
If the camera works flawlessly when the engine is off (Key in Accessory mode), but drops out strictly when driving, the 12V power supply is unstable. [1, 2]
  • Smart alternators on modern Mercedes Sprinter chassis constantly alter voltage output to save fuel. If the EmpirBus or reverse light circuit drops below ~11V momentarily, the BC 50 transmitter will reboot.
  • If this pattern matches your experience, it may require a 12V power relay or a simple inline voltage stabilizer installed on the transmitter’s power wire to feed it a clean, constant 12V.
That AI info seems to confirm what we are experiencing in ours when wifi is accessed mid drive, but of course may not be what others experience of course.
Hadn’t done that search before, maybe AI has been reading my mind or my computer!!!!!!!!!!!!!!!!!!!!!!!!!
I will be going to have a look at what our signal strength settings read out at in the Tread
Does anyone know where the ‘transmitter box’ for the BC50 is located? might see if that is an option for us also.
Sorry if this is old ground and have done the above troubleshooting already to no avail and for the length of this message!!!!
Hope it might help though........
The transmitter for the bc50 is in the small cubby over the bed behind the shower. It’s a black plastic box about the size of a matchbox.
I think your plastic pal is overreaching there. I don’t think there’s any aluminium in the body of Xtura. I do agree 2.4ghz is probably crowded though.
Which does give me an idea, I could turn the teltonika 2.4ghz network off.
I still really think the symptoms feel like noisy power to the BC50 being the culprit. It just feels like overlapping connection attempts.
I think that the real solution for this lies with Garmin, EuraMobil and Mercedes and our way in is EuraMobil probably via the dealers. I don’t really think everyone tinkering away on their own will solve it.
I think we should act as a group, draft a formal mail/letter quoting UK and European consumer law specifically: UK Consumer Rights Act 2015 requires goods to be of satisfactory quality, fit for purpose and as described; EU Directive 2019/771 establishes equivalent European standards for conformity, including advertised functionality, with additional obligations potentially arising from manufacturers’ guarantees.
I’m happy to write the letter and send it. Would other Xtura owners be interested in such a thing? Would anyone be willing to ask the Facebook lot if they’d be interested in co-signing? John and Jo?
Yes, although I don't bother with that camera, and dont get too excited about it but it should work.
Are we just talking about the UK owners, and what about the dealer involvement. Your suggestion is going to Garmin, EuraMobil and Mercedes via the dealer?
AI Response:
I'll DM you, I had all the same BC50 issues, and now I don't.
No, I wouldn't support the letter yet, but understand the angle you're coming from. I am already in an email conversation with a top guy at Mercedes, two people from Eura Mobil and Steven at M&C.
Everyone is being incredibly helpful at getting to the bottom of things and working it out.
A few of us are away this week so it'll be picked up early November.
No van is perfect these days, in fact whatever you buy there's always issues of some sort, it's how life is nowadays.
There's nothing wrong with the Garmin transmitters, where they are mounted is fine. I even now have a second transmitter for another BC50 camera. They are designed to transmit up to 30m.
A meet up with us Xtura owners, to share our thoughts and what we've learnt, would be a better idea.
I think the problem is that your solution is to wire the BC50 into the leisure battery, and that's not something we want to do. I suspect the issue is somewhere along the Mercedes / Eura interface, where the BC50 is not getting signalled correctly to come online.
I was thinking of going to Eura and M&C at the same time. I was also just thinking UK but, I'm more than happy to include the Germans if they're interested.
Like you, I'm not that bothered about the camera (or TPMS) but I paid for it and the Tread is pretty useless apart from this :-)
On TPMS BTW, Jackson said Euramobil had got something to tell us.
46stm I think we've all been in conversations with these people but fixes never come from them :-) we spoke to Frank at EuraMobil about it but zip happened.
Hi Jane, just curious, why would you not try the leisure battery power supply?
We don’t want the risk of anything draining it.
Fair comment, hence why I added a switch, with a light as a reminder to turn it off at times. Although at under 1amp draw, unless you've turned your MPPT's off, the reality is it won't really happen.
Thanks, that is the cupboard where our router is located so think that explains our intermittent issue when underway.
Also, with the symptoms others are getting it makes sense that the power signal activating the camera (drive or reverse) is a potential problem given what you say and have read here and the tweak by https://www.motorhomefun.co.uk/forum/members/46stm.123966/ to a direct feed.
I wonder as there appears to be an inherent time lag between selecting gear, the BC50 waking up (power signal) and then establishing wifi connection and finally communicating with the Tread there are several steps that any one of them can cause an issue? By providing that 'always on' power supply (albeit manually switch controlled for power conservation) would seem to shorten that process and readies the BC50 for action?
So with those standard startup steps it could be that there are several issues that can arise in any one trip and not sure how each event can be tracked to the specific issue each time a drop out occurs to find a solution to rectify it, if possible?
We are not at the stage of formal mail etc, ours is more of an inconvenience, when it does occur, in the grand scheme at this time .... will see if other symptoms show up as others have experienced on our further jaunts. Happy Motorhoming!
I would be happy to sign a letter explaining issues and wanting a resolution. If it includes ref to UK sales acts etc.. then not sure Non UK would be relevant though.
On a completely different topic.
I have found a solution to an annoying issue. We have a WiFi router which we often connect the Tread and Serv7 to. However, this connection can drop and when we reconnect the Tread and Serv7 will sometimes claim our WiFi is "Not in Range". Very annoying when it happens, as the WiFi connection does not appear in the available list.
It turns out that all our Garmin kit uses legacy WiFi tech and is therefore limited to 2.4ghz and most importantly channels 1 to 11. Our WiFi has the channel set to auto and tends to select either channel 6 or 13. When 13 Garmin kit cannot see it. Change settings to use Channel 9 and bingo all works reliably.
Garmin also it seems gets confused by mixed rate WiFi that support both 2.4 and 5ghz.
