Error Truma combi 6E diesel..
Denmark
fiat ducato chausson
this is written via google translate.
I have a Truma combi 6E diesel, year 2019.
I got error E100H.
Do you have a tip for me on how to solve this problem ?.
Have a tip on where I can find an instruction manual on how to separate the truma ?.
Possibly. a workshop manual.
happy new year
flemming
denmark
It seems that the E100H fault code relates to either:
1. Faulty cable harness, or
2. Short circuit on the solenoid.
Hope that helps
Hope that helps
thanks for your answer, unfortunately I am not sure what this means ... if it is fan motor that is defective ... ??
I want to know a little more than the one I separate the Truma ..
Check out the error codes on the attachment for your Truma...Closest is E111H ? You may need to translate it back to your own language
Regards Kev
Short circuit at The solenoid coils…. Replace cable James kit??
First thing I always say is does it work with the engine running to eliminate low power
