Hi all
What a day. Ferry delayed by 3.5 hours this morning. After sitting quietly in my lane started the engine and got the Orange EML light on, foot off and the revs dropped to around 9k but when putting the throttle down nothing happened.
Turned off, started again and kept the revs up and managed to get onto the ferry.
Went to get off the ferry and the same scenario. Stalled/cut out and needed to restart twice to get off so just kept my foot down and let the engine rev. Once it had warmed up it managed to keep going but still the EML was on. Pulled in at Cite Europe to check under the bonnet, nothing obvious there and as the engine was warm it started and ran normally With the EML still on.
Set off heading South and the first hill saw me dropping to 4th gear but we managed to keep going but down too 3rd gear on some of the hills but running quite well on the flat at 80-100kph. No doubt fuel consumption is higher due to changing driving style As well.
Arrived at our first planned aire, parked up and tuned off. First beer now in hand so…
Forum research is pointing towards one of 3 things.
1. Fuel starvation - possibly blocked fuel filter. But why would that get better when warmed up.
2. Hole in a breather or vacuum pipe ?
3. EGR faulty/stiff. Again, why would that get better when warm.
As the van is pretty well used, good run in January then standing until beginning of March. Run 200 miles on Tuesday, 150miles Thursday I don’t see if being DPF type faults. The getting better when warm seems to rule out a sensor fault.
Is there anything I have missed?
No point calling breakdown out on a Friday night so will probably sit tight until Monday when garages are open and then start the proceas.
Any thoughts or things I can check?
BTW. AutoTrail 2014 Fiat Ducato 2.3 Engine.
