Engine ‘sticking’ when driving
davidbuckett
peouget boxer
I have an 04 Peugeot boxer van and just recently on longer journeys the engine ‘sticks’ for about 5secs where the revs and speed stay the same but there is no acceleration, it then resolves itself. It has happened at slower speeds and at faster speeds. All other dash indicators are normal and it happens after about 60 miles and started just once in a 100mile journey but it’s now happening about 3 times each time a do a long journey. Any ideas?
Diesel presumably?
Have you had it checked by a dealer?
Intermittent blockage in the fuel filter?
Throttle control rod/cable sticking?
Automatic transmission lazy to change up/down?
Dunno.
Maybe try changing the fuel filter first and see if that helps. I’m sure someone who is more mechanically minded than I am will come along with suggestions.
Is the pedal/cable sticking, can you press the clutch in and see or feel if the accelerator jumps up a bit as it frees?
Not sure what you mean, If the revs stay the same there will be no acceleration. Do you mean the revs don't increase if you put your foot down? Not sure if yours will be fly by wire, meaning it's a sensor on the accelerator rather than a direct connection to the throttle body. It could be that playing up.
My only other thought is could it be something to do with the cruise control? Does it have it?
Or,going back to mechanical possibilities and the fuel supply,does that engine have a fuel pump that’s faulty? Might be a stupid question but worth asking someone who knows……your local garage?
OP. davidbuckett have you resolved the problem………let us know!
If you have ruled out a fuel supply issue, as in replaced the fuel filter and checked supply pressure, ruling out the pick up pump, then I would suggest a sticking throttle body or bad sensor
If it is I would suspect an intermittent fault there more than fuel shortage.
There would be a modern potentiometer at the pedal and stepper motor at the pump... Either could have a glitch.
A blocked filter or failing pump would cause it all the time, not just now and then.
I had an issue with my Mass Air Flow sensor that caused similar problems. It was fine most of the time, but then, normally under acceleration, it would feel like it was being choked and breathless for a few seconds. The engine also ran a bit rough at idle and I got slightly worse MPG. I replaced the MAF and it cured the issue. But when taking it to bits I found the electrical connector probably wasn't in properly and there was water in the pins. I might have got away with just cleaning the connector.
