EM50 where’s the Fuse please
Ronaldbeanio
Fiat autotrail
Hi was wonder if anyone knew where th fuse was that controlled the EM50 on my dads Fiat Autotrail 635 as the red light has gone out and now the step will not close back in and he’s here in the south of France wanting to go home any help qouks be great thanks
Paul
cant help with fuse but our step will push back in manually and doesn't seem to affect future operation
I had an issue where I couldn't get mine in and had to move, but push gently they might not all be the same
Is it a 2009 as I ha e tried but don’t want to break it
Paul
Hi ya
It comes up with blank screen....
It opens a document for me ok. The fuse allocation copied below: I hope it helps.
Fuse Allocation
F1 = 2A EM50 Supply
F2 = 7.5A Marker Lights
F3 = 20A Heater **
F4 = 20A Air Conditioner **
F5 = 20A Electric Step
F6 = 5A Awning / Entry Light
F7 = 20A Fridge
F8 = 20A Split Charge Supply ** F9 = 20A Vehicle Battery
Autotrail are good at supplying old manuals and their website offered this:
Thank you will try and remove fuse and see if broken or drop a wire across as really need the step in before they leave ??
On some steps there is a pin you can remove to allow the step to be retracted manually.
Ref Autotrails. There is a known issue on some years / models where there was a batch of faulty components called "polyfuse" a self resetting fuse that is built within the Sargent main control box. Needs a physical repair to fix if that is the case.
Another common issue ref Autotrail step retraction is low power in the leisure battery and also the actual step mechanism being dirty and clogging up the moving parts creating a strain on the battery.
Good luck with getting it sorted.
