Morning
I have an EBL269 with an LRM1218 solar controller.
Just back from an Easter break and while the new battery didn't drop below 75%, I did find that with strong sunlight, I was seeing up to 8amps from the system, but the LRM would quickly decide that the battery was full and trickle charge (at a reduced amps).
I'm not sure if it is the battery BMS refusing the charge or the LRM1218, or even the EBL (as the LRM1218 is connected to the EBL).
Before I remove the LRM and fir a Votronic solar controller (that does support Lithium), anything else I should check?
Si
Si
