An even better way is to twist the rope the opposite way on each turn. This means that the twists on the rope are cancelled out. This method is useful for protecting fragile electrical cable such as that used to connect medical cameras to the monitoring equipment. Also useful for audio cables to reduce risk of breakage to the conductors.Learn to coil it. If you sign up for a RYA Competent Crew course you will learn how to coil a rope. I use the same technique on the EHU lead.
I suspect there are YouTube videos on how to do it but the trick is twisting the cable as you make each coil.
Sorry don't agree, the twist is to cancel out the winding action as you coil, if you continue to coil in the same direction then the same direction of twist is needed. Perhaps this would work if you are reversing the coils on specialist equipment but a bit tricky on a heavy ehu cable.An even better way is to twist the rope the opposite way on each turn. This means that the twists on the rope are cancelled out. This method is useful for protecting fragile electrical cable such as that used to connect medical cameras to the monitoring equipment. Also useful for audio cables to reduce risk of breakage to the conductors.
Obviously different methods work for different materials and needs.Sorry don't agree, the twist is to cancel out the winding action as you coil, if you continue to coil in the same direction then the same direction of twist is needed. Perhaps this would work if you are reversing the coils on specialist equipment but a bit tricky on a heavy ehu cable.
Interesting, I have been playing with both methods. They both store the cable or rope without any twists, the difference comes when you release them.Obviously different methods work for different materials and needs.
If you have for example 10 coils in the rope doing it your way and you hold the ends of the rope in each hand and let go of the coils then you effectively have 10 twists in the rope.
After reading all that, I think I'll go wireless
Is this for real ???Ive just gone over to bluetooth electric on sites.
You don't have to park too close to the outlet box and sometimes get free electric the same as you can with the wifi
Just so much easier than using cables
No. But Mr Tesla did propose wireless AC power delivery apparently.Is this for real ???
I don't coil the EHU cable, I use the daisy-chain method instead, then it just gets shoved in the gas locker for storage. The beauty of the daisy-chain is that its quick to pack away (once you've got the hang of it), it can't get tangled no matter how small a locker its pushed into, and because its not a coil you don't need to fully unwind it each time you use it
blue tooth is a one to one protocol so useless on many french airs ive got wirless which i can shareIve just gone over to bluetooth electric on sites.
