ludo
1.7 amps according to the German instruction manual for mine.
I can see your point but it might be a good idea to get one with a double pole switch to allow for reversed polarity hook-up posts. Assuming you are fitting an RCD device on the incoming mains, would that not suffice?
When at home and connected to EHU, the ELB99 is on unless I withdraw the plug feeding it. I only leave the ELB99 connected to the mains for, perhaps, 2/3 days, every month or whenever batteries fall to 12.5v. Using the new switch makes it easy to isolate the ELB cleanly and easily.
