Edge banding
Citroen Relay
On and off since 2011
I have lightweight Moreland ply overhead lockers with flush fitting doors. I.e. with doors closed the surface is flush. I would like to edge band the doors and the inside edges with hot melt edge banding. This will be time consuming and will no doubt make me grumpier than usual. My question is - has anyone used hot melt edge banding in a van so that it stays on in hot weather? Don’t want to spend ages doing it only to find it all comes unstuck in the summer.
Thank you.
Thank you.
I would not worry to much as the iron needs to be set to about 200 degrees C (cotton setting) to apply the edging. 👍
A quick tip, do not use the iron directly on the edging as it will likely scorch it, use a sheet of A4 printing paper folded a couple of times to save any glue that oozes out sticking to the irons plate as well. I edge banded thousands of metres by hand and on a machine when I was a shop fitter and joiner.
Yes, and I did a video on it. I did all my own
We've been in 46' external heat. And none has come loose due to heat.
I did use the "correct" banding, hot air gun, rollered it on, and trimmed using the correct tool and the finish is "pro" standard. I'd not use B&Q banding
Inside edges challenging.
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
All bits edged, internal, external, 90's and curves. Including the flush bits.
Watched it. Helpful. Glad I asked👍
