We were a lucky winner of the recent 50% discount offer from Ecotree on one of their 120Ah Lithium batteries. This was great timing, as although our current batteries are still performing OK, they are coming up to 6 years old.
So following a chat with Rob at Ecotree we decided to get the new battery and update our installation ourselves.
We have a Hymer Exsis 578I, and the standard install was a single Varta AGM 95ah battery and an Electroblock EBL29. From new I added a second Varta battery and an Schaudt LRM 1218 MPPT solar regulator with a 150w solar panel. This has worked well, supporting us for long stays off grid when touring in the summer.
The main aim for the update is to save some weight, and freshen up our batteries. Although they were still ok for our use, they must have lost some capacity over time. The last thing we want is for them to fail while were travelling.
After checking our install with Rob he agreed that a simple battery swap would work well.
The capacity of our 2 AGMs was 190ah when new. This would give a useable max of 95ah which is probably now down to 70-80ah max, probably less given the way lead acid batteries charge/discharge. The new 110ah Lithium will easily match or beat this, even if we stick to a conservative 75% discharge use.
The gel setting on the EBL29 would be suitable, and by switching the charge profile on the LRM1218 to AGM2 that would be ok too.
Our van doesn’t have a smart alternator, and as we aren’t too bothered about maxing the charge rate when driving he advised not bothering with a B2B to start with. One can always be added later if needed.
We have a NASA BM1 Compact battery monitor which is ok for basic monitoring but I’ve decided to add a Victron Smart Shunt to better manage our battery usage.
Here’s our current setup.
So plans sorted, battery ordered. More to follow!
