Easy lifter hydra trail(again)! (1 Viewer)
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
We are currently touring in Holland at the moment with the Easylifter Hydratrail trailer and Yamaha YBR125, my perceived problem is that when towing forwards, the bike and trailer tilts towards the Motorhome by about 15 degrees making the bike look a bit ready to fall off, although it cannot due to the upright adjustable seat clamp and straps at all four corners, also the footrest end is up against the central pillar as well.
The only time that it is upright is when I have reversed and then the bed and bike are level, is it me, or am I missing something??.
The photo shows the trailer after reversing onto our pitch.
MikeD
3,936
3,697
London
IH PVC
Since 2012
I don't remember mine doing that. But in all honesty I can't say I looked. :)
Oct 2, 2008
4,469
7,955
Salopia
Duro 6x6 Overlander
since 1968
It must have to do with your tow bracket as the way it is designed
the parallel links keep the trailer post parallel to the towing vehicle post the trailer vertical is fixed at 90 degree to load bed .
Rob e Lee
452
575
Surrey
Since 2011
When I tow mine it leans as you describe and never had a problem. I've covered about 5000 towing miles.
Rob e Lee
452
575
Surrey
Since 2011
Just another thought, nothing to do with angle of towing but do you use supplied jack to lower bike?
Oct 2, 2008
4,469
7,955
Salopia
Duro 6x6 Overlander
since 1968
Have you tried seeing if the tow post (fixed to tow bar) is vertical using spirit level ?
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Assuming everything is firmly attached to the van & towbar the only thing that will cause the effect you describe is the angle of the steering pivots. On flat ground they must be leaning away from the van to cause that effect. You need to check that with both van and trailer on level ground the trailer bed is parallel to the ground. Which will ensure that the steering pivots are at right angles to the ground.
injebreck99
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
That’s the trouble, the only time that the trailer bed is parallel is after reversing, that brings it level, when towing forward, the bed is tilted towards the van.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
The answer is still the same. The only difference between forward and reverse is the position of the trailer wheels. If the steering pivot isn't vertical the effect will be as you describe. For all l know the steering pivots aren't intended to be vertical so the effect could be normal.
MikeD
3,936
3,697
London
IH PVC
Since 2012
You can get "long reach" towballs if you are worried that it might hit the van.
They should push the "upright" out a little to give more clearance.
Vic
Aug 1, 2010
461
536
I find if it leans too far out or in, then it is my fault when initially tied down. I tend to give it a mile or two, pull over and check the angle. A couple of times I had to wiggle it and re - adjust the tie downs to straighten the scooter.
injebreck99
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
I always load the bike when the bed is upright, ie, vertical, but it still leans over towards the van when towing forwards.
Jul 24, 2009
4,330
104,335
South Yorkshire
Since 1999
When I had the Hydratrail I found that there was a difference between forward and reverse due to the wheels castoring and in effect moving the centre of gravity forward in front of the scooter causing it to tilt backwards. It is all the play in the linkages and clearances in the box sections that allow this.
musson
487
165
grantham
low profile
since Jan 2014
My friend had this on a new one and it was the towing bracket attachmnet had bent
injebreck99
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
I have studied mine in detail, and cannot see anything out of line, it just seems that the parallel arms are at the wrong angle, but what do I know!
musson
487
165
grantham
low profile
since Jan 2014
Best ring easy lifter to be safe 01509 268400 just incase you dont have number
Jaws
23,836
72,460
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
When I bought one I was told by as near an expert in tow bars as you can get, that it would twist the tow bar, and in less that a mile it had.
Check the bar is vertical and it has not twisted
injebreck99
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
Turns out that the horizontal bar that the tow ball attaches to was slightly loose allowing the upright post to move a fraction, I have levelled it and retorqued the bolts, should be OK now.
Paul and Jeannette
86
51
lincoln, lincolnshire
coach
20 years on and off
What is the verdict on the Hydra Trail as I have asked a few owners on site and the opinion is a bit like Marmite.
A few said they liked the reversing but would never buy another.
Speaking to the supplier if you have a problem also seems a bit of a problem according to a few.
I have the easy lifter on my tow bar but keep thinking I would love to try the Hydra but it is expensive although all second hand ones seem to sell around the £800 mark.
Silver-Fox
9,265
29,071
Cheltenham Spa
Rapido
im a not so newbie
@Paul and Jeannette ive got one but only used it once.
Found it great for towing and reversing, but I don’t think I could faff around lowering and lifting it back up.
I made a ramp to load up, much easier.
Oct 2, 2008
4,469
7,955
Salopia
Duro 6x6 Overlander
since 1968
If you have the lifter , why would you want to try the trail , just curious , as I have lifter ? @Paul and Jeannette
