As the system is levelling the vehicle.
I don’t have the system, but I’m weighing it up for the new van. Have seen some videos online and they seem to been as the jacks lower. I’m just curious if this is a standard thing.
Straightforward answer, thanks!Are you sure it's the E and P?
Mine doesn't...
But the air suspension does beep if its not in service mode when using the e and p
It was an E&P system I saw beeping. One was a demo set up at a show, I guess for safety in a public setting, and one a caravan in this video….
My good lady thinks it’s a sensible investment, so the only problem I had to overcome is already resolved.![]()
I take your point Lenny but I was more thinking of the weight of the kit and pump. With a lot of caravan only having a small payload it taking a big chunk out of itInteresting only two rams on a caravan & powered corner steadies but corner steadies are what they say steadies you are not supposed to take the weight of the van on them as it can twist the chassis.
With it essentially being a trailer and the weight pivoting over a central point, I see why the front and rears are only steadies and not full rams.Interesting only two rams on a caravan & powered corner steadies but corner steadies are what they say steadies you are not supposed to take the weight of the van on them as it can twist the chassis.
Probably getting on for 50% of payload.I take your point Lenny but I was more thinking of the weight of the kit and pump. With a lot of caravan only having a small payload it taking a big chunk out of it![]()
Not the weight it's the twisting of the chassis.E&P replace the existing caravan steadies with their heavy weight made version for the purpose of taking the weight.
