ShiftZZ
What is the size of the 'foot'/baseplate?
Ta
Ta
All those electrical and hydraulic gubbins look perilously close to the exhaustIf you wanted a bigger footplate area, then you can fit these covers as I did, which takes the diameter out to 270mm and they have a textured finish on the base for grip.
These stackable pads are a great accessory for difficult sites.
Stackable Motorhome Pads (Pk of 4) | Outriggerpads
www.outriggerpads.co.uk
Get a cheap garden center knee pad for that issue . Of the sites I have been on in the last four years I have needed them around 85% of the time. My Bailey/Peugeot combination sits slightly nose down normally so these assist the hydraulics in achieving level.If you like crawling around on your hands and knees they are.
Hi PaulIf you wanted a bigger footplate area, then you can fit these covers as I did, which takes the diameter out to 270mm and they have a textured finish on the base for grip.
Hi Paul
Can you provide a link for these covers please
We have E&P and if you are a member of the C&MC you can get the big feet for free HERE
ObviouslyBut only on a new install of an E & P levelling system, not to buy if you already have a system on you van.
Obviously
Not obviously at all unless like Paul highlighted, ie, one has to follow your link to find out that as previous customers, they don't qualify whatsoever.Obviously
I have just bought a set of these and it led me to identify 2 jacks where the rubber o rings were disintegrating and one plate was quite loose so that has been a good exercise as I have just got some new rings. Only just 2 years old! I have been looking closely at the plastic and I wonder if it will sustain a sharp stone dead centre under the bell of the steel disc? Any experience with these cracking or splitting?If you wanted a bigger footplate area, then you can fit these covers as I did, which takes the diameter out to 270mm and they have a textured finish on the base for grip.
Thank you very much. I spoke to Rob at SAP who was most helpful and is trying to source them. Regards.Try Mick at SAP for the exact ones, or find a local general hydraulic company, take the damaged ring in and they will match it.
