Yes you need the stuff from UK Power Networks. ?don't forget, ebikes use special electricity, not the normal stuff from a wall socket. the stuff you need is more energetic to help make the wheels turn
It's not quite as simple as slapping on an inverter. E-bike batteries take a lot of charge. Some have 500Wh capacity, which is enough to drain a 80Ah habitation battery. Of course, you may not be recharging the e-bike battery from flat but all the energy has to come from somewhere and there's a lot of it in some e-bike batteries.Thanks! Do you have a link to where I can buy the inverter please?
The one I’m looking at is 400WHIt's not quite as simple as slapping on an inverter. E-bike batteries take a lot of charge. Some have 500Wh capacity, which is enough to drain a 80Ah habitation battery. Of course, you may not be recharging the e-bike battery from flat but all the energy has to come from somewhere and there's a lot of it in some e-bike batteries.
I'd only plan to charge an e-bike battery from EHU.
Thank you - helpful adviceWatt-hours are the units you need to be looking at. I was simply trying to point out that a 'standard' habitation battery has a fairly modest capacity and similar to that of some e-bikes. It's not good to 'exercise' your habitation batteries so much. If charging via inverter, I'd only do so whilst on the move and get the alternator to provide some power. If you go that route, you'd be well advised to add a Battery to Battery charger to boost the power obtained from the alternator. Doing all that will not be cheap. Don't forget the cost of installation as well as the price of the kit. For all that, I'd think about a second e-bike battery and keep that as a spare to tide you over between mains connections (on EHU).
And don't use wind turbine power because the person behind will know you've got wind issues.Whatever you do don't use Scottish Hydro electricity, the motors rust away in no time at all.
We have recently been through this process.Quick question - I’m planning to buy an e bike. Can you recharge the battery using direct plug in to the hook up , or do you need a separate system?
Yep just a couple of mains sockets on a pole by a bike rack.I assume you'd need to use your own charger.
I wonder if they're used much. Our trips are always within the range of the battery, so we never have a need to recharge en-route.
For comparison with a leisure battery capacity, convert 400Wh to amp-hours from a 12V battery:The one I’m looking at is 400WH
The 12v charger was silly money & took twice as long to charge a battery, it's now been discontinued.Both our bike use a Bosch batteries, spares are very expensive but they did do a 12V charger rather than 240v which is a lot more efficient. As other have said they do take a lot of power from the hab battery.
If you get an inverter make sure it is pure sine wave as teh chargers do not like the modified ones.
But charging more slowly hammers the batteries less and time is not normally a problem if you charge immediately on return rather than waiting until just before the next trip.The 12v charger was silly money & took twice as long to charge a battery, it's now been discontinued.
But when you have 2 to charge and it's going to take over 6 hours each. Anyway discontinued.But charging more slowly hammers the batteries less and time is not normally a problem if you charge immediately on return rather than waiting until just before the next trip.
