E 21 H Truma fault reading (3 Viewers)
Jan 3, 2017
215
122
Huntly
Frankia i640 SD
Getting this fault reading E 21 H on our Truma and it says the fault involves contacting Truma to resolve. Has anyone had this problem and if so how was it resolved.
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Some times it will clear by itself, sometimes if you switch the 12v off while it is on it will give you an error code.
Try switching everything off and start again....
Edit. #21 suggest a temprature sensor/ cable/ fault.......have a look around the sensor.
Cairngorm
Jan 3, 2017
215
122
Huntly
Frankia i640 SD
Tried switching everything off and it made no difference at all. Where is the sensor, is that the black bit above the Truma control.
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Mine is above the hab door about 10 inches from the control unit,
Sep 16, 2013
2,219
7,913
Horncastle, UK
By any chance, when first switched on, does it try to start, then stop after 20 odd seconds and display this code?
Cairngorm
Jan 3, 2017
215
122
Huntly
Frankia i640 SD
No attempt to start at all. Heating doesn’t fire up and the fan does not start at all.
Cairngorm
Jan 3, 2017
215
122
Huntly
Frankia i640 SD
Yes everything was switched off but still no joy. Dealer to fix, looms I fear. One guy said March would be there next appointment.
Sep 16, 2013
2,219
7,913
Horncastle, UK
Shame. Just wondered as I had this issue.
On mine I switched the boiler off, then pulled the fuse for the control panel to kill it completely.
I then left it 5 minutes, replaced the fuse to switch the control panel back on, left it another minute and switched the boiler back on.
It then tried to start for about 30 seconds and then the same code came up (could hear boiler and fans during this time).
I repeated the above and it started working again.
Portland
923
1,424
Conwy
20 years
I did this with mine working on the same basis as my pc take out the supply entirely press buttons for about 30 seconds to discharge system completely and restart
Dare_Devil_Dennis
296
199
Derby
E21H is listed in the manual as "Room temperature sensor or cable faulty"
The sensor is a thermistor whose resistance depends upon the temperature.
53,421
149,939
On our last van we used to get random errors including that one, particularly when using the timer, ours was 2014, a software upgrade cured it.
Dare_Devil_Dennis
296
199
Derby
They are about £35 each! often special order.
Test it first with a multimeter on ohms range. Should get a reading in the 1K ohms or less
Cairngorm
Jan 3, 2017
215
122
Huntly
Frankia i640 SD
Not sure how you switched the boiler off. Was that a fuse as I just pulled the fuse out for the control panel to get it zeroed but the fault reading was instantaneous, with no fan or boiler noice,when the power came back on.
Cairngorm
Jan 3, 2017
215
122
Huntly
Frankia i640 SD
could be worth trying a DIY repair and changing the sensor?
or
You were quite correct in your assessment of the situation. I didn’t read your post till the next day. I remember hitting a pothole on the road and that caused the sensor to become disconnected and the boiler to stop working. Took it to the local Truma dealer in Inverness to get it fixed.
Unfortunately on leaving the mh by the side door I managed to break a pin on the locking mechanism, which means I can get out the door , but once it’s closed, cannot open it from the outside.
It’s not always fun and games being trailer trash.
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
Your door problem seems to be a recurring Rapido issue! Happeneded to us as well with the exact same problem as you. There is also another Rapido hab door lock thread on MHF as well. If you figure out how to replace the key barrel let me know please! - I think you may need a special key as far as I can tell.
