Ducato (X250) 2.3 150: turbo boost sensor location ? (1 Viewer)
Ridgeway
3,655
6,151
Lausanne
NiBi Arto 85E
Since 2012
Can anyone point me in the right direction as where I can find this ?
I have P0238 and P0238 codes which indicate low and high pressure faults. It seems reasonable to check the sensors cables first.
wizza
175
117
Essex
low line
8 years
I would suspect the boot pressure sensor is reading correctly check the boot selonoid valve and make sure the vacuum pipes are not split it sits behind the bracket behind scuttle
Ridgeway
Ridgeway
3,655
6,151
Lausanne
NiBi Arto 85E
Since 2012
Wizza what do the vacuum pipes look like ?
Are they connected to the Dytech 460 unit ? as these are black rubber pipes that are 4mm ID and roughly 8mm OD, both pipes are totally destroyed, could it be these ?
Ridgeway
Ridgeway
3,655
6,151
Lausanne
NiBi Arto 85E
Since 2012
This is the Dytech B460 unit:
One of the pipes that comes off a T that has been chewed
Nov 7, 2015
497
469
Newport, Shropshire
Autosleeper Broadway
since 2015 previously caravaning 25 years
Dytech is just the manufacturer but well done for locating the problem, a new length of pipe will fix your problem :)
wizza
175
117
Essex
low line
8 years
I sits behind that unit but them pipes split can cause overboost
Ridgeway
Ridgeway
3,655
6,151
Lausanne
NiBi Arto 85E
Since 2012
OK to close the loop on this. I replaced the vacuum hose (there are 3) and still got the same error messages. I then cleared them with an OBDII bluetooth device and it's all sorted now:) no more error messages and now the turbo is whistling away again.
Ridgeway
Ridgeway
3,655
6,151
Lausanne
NiBi Arto 85E
Since 2012
Forgot to say thanks for the help on this, another great example of why the MHF subs are well worth it, saved me a fortune !!
PS: reading all the other "upgrade" threads does cost me a fortune though:LOL:
wizza
175
117
Essex
low line
8 years
Glad you got it all sorted
