Ducato windscreen washer not working (1 Viewer)
Sep 21, 2013
226
241
Isle of Wight
coachbuilt
since Apr 2013
The windscreen washer on my 2000 regd Ducato isn't working properly. The motor sounds as though its working but no water is coming out, even when I disconnect the pipe at the motor. Due to air filter and alarm gubbins I cannot see how the motor detaches from the bottle. Is it a twist or just straight pull or am I going to have to strip god knows what out the engine compartment to get at it.
Thanks for all the useful replies I will get and also for all the funny ones too.
TheBig1
17,509
42,755
as far as i remember it just pushes in and pulls out. buy the new pump you need to fit and confirm
Nov 4, 2011
5,886
38,109
Uk
I had this problem with my 2001 fiat ducato base,removed pump (just pulls out, upwards) and the filter was blocked with jelly type stuff, cleaned and all ok.
vectian
Sep 21, 2013
226
241
Isle of Wight
coachbuilt
since Apr 2013
Well I got it fixed this morning but to make it more accessible I took the airfilter off, which wasn't too bad and gave me enough room to get my hands in.
As with Manic it was completely fouled with jelly gunk. I want to know who put the jelly in there in the first place.
Thanks for all the replies and help
ambulancekidd
Sep 23, 2014
10,303
28,339
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
When you put it back in after cleaning it I found it easier to put the rubber grommet into the bottle first then push the pump into that
Thanks for that tip, should make the job easier (y)
Feb 18, 2019
29
129
South Wales
Adria S 690 SP.
2018 August
Simple way to replace windscreen washer pump. Take 4 10mm bolts off top of grill. Remove grill. Undo 2 10mm bolts holding headlight in and drop down headlight (There is a popper on the outside of the headlight just give it a tug). The washer bottle and pump is completely exposed and easy to work on. Just replaced my pump and start to finish 11 mins
ambulancekidd
Sep 23, 2014
10,303
28,339
Ayrshire Scotland
Swift Kon-Tiki 640
My washers have packed up again, flushed the tank, no change but, noticed that the pump was very hot.
Its a sealed unit so I couldn't simply grease the ends of the motor itself.
New one ordered & should be here tomorrow.
Lenny HB
52,685
147,592
On the coast in West Sussex
Hymer B678 DL
Anyone remember the powder you could buy instead of the concentrated liquid, that used to gum up the pumps with gelly like gunge. Someone may have used it in the past.
