Ducato whistling engine noise
cbrown1360
99
29
Lymington
Since 2014
My Moho is on a Ducato Euro 6 150 go. base. It’s only 6 months old with 4000 miles. The engine has developed a high pitched whistling noise which changes pitch with engine noise. I am in Spain at present so a little concerned about taking it to a dealer. There is no discernible fall off in performance. Someone on another forum has suggested it could be the idler bearing on the auxiliary belt tensioner. Is this a serious problem? Any advice would be most welcome.
Aug 18, 2014
18,348
80,237
Lorca,Murcia,Spain
Transit PVC
6 years since restarting
Find a Fiat dealer. It is under gtee so wouldn't be a problem. Where abouts are you ?
Nov 23, 2015
2,509
2,180
Newmarket,Suffolk
Benimar294
Newbie
TerryL
5,408
6,805
North East
Low Profile
Sounds a bit like a leak on turbo inlet pipe; would think that's more likely on a new van especially if it disappears occasionally. Probably just need clip adjusting/tightening up - simple job but I've no idea where it is mind!
Good Fiat service agent should solve it in seconds!
Xabia
1,234
861
Rural Nottinghamshire and Spain
Since 1996
I can recommend the Fiat Professional dealer in Denia, on the right hand side of the dual carriageway from the motorway to the town. Sorted me out without hassle on a couple of occasions.
Edit: Automocion Moll is the name
Wilderbeast
92
85
Stockton on tees
"Hymer duomobil" B634 SL
Since 2011
Couple of years ago ours developed a whistle (3ltr 180)varying pitches and coming and going.Had it checked out by FIAT and no fault found!!
Travelling through France started again ....... it was infact feed back through the speakers from the sat nav plugged in to stereo aux point !!!!
Now sorted and whistle gone
D
