NorthernSands
Hi all,
Does anyone know of anywhere that sells aftermarket push button dash switches with different pictures on? Our Fiat base has the flat square type. I'm used to finding things like that for Land Rovers, but I've not found anything for the Ducato.
Failing that, does anyone know of a genuine switch that's a simple push on, push off affair? I could always sort the decal afterwards. I did try looking for part numbers, but Eper seems permanently broken, and fiatdalys doesn't have any part numbers for the flat square switches (only the round ones).
Reason for asking is that I'd like to fit a switched relay to control power to the cigar lighter (now a USB-A/C charger) and stereo. At the moment both are permanently on - and the USB charger has a voltage display that's quite bright. Switched relay so we can use them even when stationary, but not kept awake with bright lights shining down the van!
Many thanks!
Peter.
Many thanks!
Peter.
