No a Fiat Maxi chassisI take it you have an AL-Ko chassis, to uprate the axle to 2700 you will need to fit Semi or Full air rear suspension semi around £2k, full £4k. You will probably also have to change the wheels and tyres, if you have steel wheels they may be OK, you need to check the load rating. if camping tyres they will need changing to a tyre with a higher load rating.
If it is possible the same would apply, you need to talk to SV Tech.No a Fiat Maxi chassis
