- Jun 7, 2019
- 440
- 1,893
- PVC
- 30+ years
Mais non, Toulouse to Dieppe in 10.5 hrs. Got to make sure its all okWhat's French for "Running in-please pass !"
Can't fault Fiat, the breakdown service or the French Fiat garage.Or a Total Fiatsco maybe?
Has that been proved now? And have they accepted responseabilty?Can't fault Fiat, the breakdown service or the French Fiat garage.
This whole fiasco was down to my local garage who did the belt change in the first place.
Its been passed to their loss adjusters.Has that been proved now? And have they accepted responseabilty?
Please read post #281Its been passed to their loss adjusters.
How can the inlet valve witness marks on the pistons be explained, other than it was mis timed at some stage?
See posts #182 & #184.
According to Fiat Professional all pulleys, tensioner and belt were as they should be ie. timing was correct, before they started stripping it.Please read post #281
It may not be, but does offer a plausible explanation .
Please let us know the final verdict if you have time.
Maybe I am being too suspicious but I wonder if the garage doing the belt change made a mistake with the timing, turned the engine over by hand or on the starter with no fuel being injected, realised it was wrong when the valves made contact and then 'corrected' the timing error while hoping that no damage had occurred?According to Fiat Professional all pulleys, tensioner and belt were as they should be ie. timing was correct, before they started stripping it.
Already been suggested, a couple of hundred posts ago.Maybe I am being too suspicious but I wonder if the garage doing the belt change made a mistake with the timing, turned the engine over by hand or on the starter with no fuel being injected, realised it was wrong when the valves made contact and then 'corrected' the timing error while hoping that no damage had occurred?
Thats exactly what has happened, there's no other logical explanation.Maybe I am being too suspicious but I wonder if the garage doing the belt change made a mistake with the timing, turned the engine over by hand or on the starter with no fuel being injected, realised it was wrong when the valves made contact and then 'corrected' the timing error while hoping that no damage had occurred?
Its not a matter of patience, its more a matter of "shit happens" and you've got no choice other than to deal with it.Good to hear your news ..... I still think you're one very patient chap
Just wondering if you had used a Fiat garage and same issue occurred if they would of fitted new engine FOC?Can't fault Fiat, the breakdown service or the French Fiat garage.
I’ve been reading this thread with interest as my 4 year old van will be due a belt change early next year. My question to the engine experts here is ‘ who would you really trust to do your cam belt changeout and what other parts would you change at the same time that are not part of the Fiat kit ‘.My first thought is to get it done at a proper Fiat Professional garage , yes I know they will be at the top end of charging spectrum but at least I reckon I would have some sort of comeback if it all went horribly wrong afterwards.Quite possible.
There have been a few threads recently on cam belt change and the cost of getting it done, I've commented on a few but given up now as many think that it is best to get the job done as cheaply as is possible, but I'll wager the budget ones do not do the job properly.
By that I mean if you follow the correct procedure it is a task that has to be attacked from top and bottom, and involves removing quite a lot of what may appear to be unnecessary and using various tools and timing pins that insure the correct timing is achieved, it is of course however possible to just remove the old belt and hope nothing moves whilst the belt is off and slip the new one in its place, which I would suggest the way the cheapo ones do it, OK if nothing goes wrong.
Part of the correct procedure is to slacken the cam pulley bolt and reposition the pulley to suit the new belt which ensures absolutely correct timing when carried out, not likely part of the procedure if looking to do it quickly / cheaply.
As I mentioned previously the OP is likely to end up with a bill of €12k or so, ask yourself "do I feel lucky" next time you choose who renews your cam belt.
As an add the picture I posted earlier was from a 2014 Ducato that had covered 44000Kms, glad I've not got a low mileage 2014 van
I’m also interested in the answer to this question.Just wondering if you had used a Fiat garage and same issue occurred if they would of fitted new engine FOC?
There are large O ring type seals that cost around £5 a piece which are not part of the standard fiat kit. I made sure these were changed with the belt kit.I’ve been reading this thread with interest as my 4 year old van will be due a belt change early next year. My question to the engine experts here is ‘ who would you really trust to do your cam belt changeout and what other parts would you change at the same time that are not part of the Fiat kit ‘.My first thought is to get it done at a proper Fiat Professional garage , yes I know they will be at the top end of charging spectrum but at least I reckon I would have some sort of comeback if it all went horribly wrong afterwards.
Your thoughts would be appreciated .
No, the garage have pased it on to their insurance company and they're just ignoring it.Mixyblob any final update?
yes definitely worth asking your own insurance company if you have legal cover & get an opinion off of them.Or small claims court?No, the garage have pased it on to their insurance company and they're just ignoring it.
We're currently considering getting a solicitor involved, anyone recommend one?
Worth asking your insurance folks what they think but I would be very wary of getting solicitors involved off your own bat on which is I'm afraid only going to be your word against theirs.yes definitely worth asking your own insurance company if you have legal cover & get an opinion off of them.Or small claims court?
Another thing they could come up with is the damage on the pistons could have been there before they touched.On top of all this the part that they did replace was as you say, right at the time.
