- Jan 11, 2018
- 1,164
- 1,348
- Chausson Welcome 85
- Since 2018
Not had our Chausson 2008 very long and just fitted 4 new tyres.
Old tyres were full of tread but of 2006 vintage.
I made the assumption that the spare was probably the same age but had been protected from UV etc. So it would still be ok as a spare.
Just so I knew the process I thought I would remove the spare and check this plus pressure etc.
What a flaming game..........
First problem , the hole in the side to take the bar to wind the spare down does not align with the socket in the wheel release , you have to half nudge it round in the gap between the wheel and the arch.
Second , took a little head scratcher to work out the cable is longer than that required to lower the wheel to the ground. You keep turning till it stops.
Third , and this is the biggie. Releasing the pull up coupling from the wheel.
Root about and find and remove the nut , not too bad but then how to get the coupling out through the wheel hole to permit the wheel to be fully withdrawn from the vehicle etc. had to do this by chocking up the wheel, still partially under the vehicle so I could see it underneath and manipulate the shape of the pressing through the hole.
Phew
At least now I know how to do it I know what I’m in for if I have a flat........
Phew
