The Nomad
The background:
Fiat Ducato 2.8JTD Benimar Spanish LHD motorhome, year 2000 built.
It's a coachbuilt motorhome on a bog standard Ducato chassis-cab, so all engine mechanicals/electrical system is bog standard.
Alternator output goes to a charge splitter which feeds both engine battery and rear leisure batteries.
The problem:
Battery light goes out when engine started from cold/after a delay overnight; but has begun to stay on when engine is restarted once warm/after having been run for even only a minute then turned off and restarted.
What's happened thus far:
A mobile "expert" auto mechanic/electrician came over to the house last week, did a few tests with his multimeter and some other kit, and declared the problem to be definitely a dodgy voltage regulator within the alternator.....causing the alternator to not start outputting charge when you started the engine.
According to his kit, there was definitely no output coming from the alternator when engine running and battery light was on.
So, I managed to track down and get an exact matching alternator 2nd hand from a breakers yard.
The chap fitted it and "tested" it this morning, declared problem solved, as when he'd finished I started the engine the battery light went out.
Turned off engine and left it.
An hour later I went to get the MH off the levelling ramps I'd run it up on for the guy to work underneath it. Started engine, light went out, great.
Turned off igniition after maybe 1 minute of ticking over, started it again, and the bloody light stayed on for maybe half a second then went off.
Tried it again and this time light stayed on all the time!
Tried starting it half a dozen times more, and every time light stays on, just as before the alternator swop.
I've got this chap coming back for another look at it in the morning, but I'm not convinced that he's actually quite as expert in vehicle electrics/electronics as he says.
I suspect that all I may actually have achieved with him so far is to get me to hunt all over Spain to buy a second working-fine alternator to swop for the original actually working-fine alternator. So I've managed to get a spare one, if nothing else!
I think what somehow MIGHT have caused this problem to start happening is when I was testing the rear lights after having removed the light clusters to repaint the bar that they sit on. Once replaced, I got my wife to stand behind the van to check each worked.
I started engine and then tested brake lights, reversing light, sidelights, headlights etc.
At the moment that I already had the headlights on and then also pressed the rear foglight button for a moment to test it too, I thought I may have heard a slight click noise from inside the left side of the dash or engine compartment, and I think that was the moment that the battery light first ever came on next to the foglight light on the dashboard. (I cannot even remember the last time I ever previously have pressed the rear foglight switch).
But haven't been able to replicate that condition since.... on the few occasions I've started the van since then from cold and the battery light has stayed off, I've tried then turning headlights on and then foglight once again and all appear to work just fine, and battery light does not illuminate
I've just now disconnected all of the connections from the two rear light clusters and then tried starting the van again, but the battery light still stays on, so I don't think the problem lies there.....at least not now.
I'm now flummoxed.
So, are there any auto-electrician Gods out there who could suggest possible causes/solution for this problem please?
The problem:
I'm now flummoxed.
