Hi all just wondering can you or do you leave the quilts on your drop down beds when you raise them back up.
Mines got no microswitches (or brains lol) so duvet & pillows stay up there with no problem
Yes we leave in situ on our Benimar Tessoro 468
Very comfortable, wouldn’t go back to cushion beds
Ditto to all of them above, leave a little gap above until we go out for the day, then drop bed down a touch to get some airflow across it.We have electric drop down beds in our Chausson 630 and we can leave the quilt and pillows on there but we have to separate the pillows.
Our Burtstner has just enough space [tested by my walking underneath the raised bed without scraping my skull] for the bed, with pillows on top of the mattress, duvet and 5cm mattress topper to be raised in situ. The only precautions we take are to ensure that the overhanging duvet sides are folded onto the mattress area until the raising bed clears the dinette head restraints and, at the cab side, the duvet side clears the reading light switch [otherwise the duvet turns off the light, and it gets very dark ... Good trick for Halloween, but otherwise a proctological irritant ...]It seems on Burstner you can maybe leave the quilt but not the pillars.
The bed has to hit a micro switch / limit switch otherwise it looses its brain
Same. It depends on the type of bed. I've adjusted the locking blocks on ours to make it a bit easier.We have to arrange the bedding carefully especially the pillows otherwise the latches that hold it up won't latch in place.
We’ve just purchased a motorhome with 2 electric drop down bed and used for the first time and raised it up with pillows and duvet on and it blew a fuse.I think people are talking about two different things here...
Electric drop-down beds. Often over the lounge on c-class motorhomes. Some of them are picky about stuff being left on top. The sensors or motors can trip out.
Manual drop-down beds. Typically over the cab on a-classes. Will normally latch with stuff on top of them if you shove hard enough...
We don't have the posh sensors on the Burstner, but if we do 'push' the motor to 'squash' the pillows, we do blow the fuse, hence the 'bonce scrape' test [Stourbridge born ...] if my hair just touches the bed underside, aka the ceiling, the fuse won't blow. We also check by inserting a finger or two on top of the pillow to check that the pillow is not crushed. The 'landing approach' finishes with 3 short prods of the 'up' button for that final clearance nudge.We’ve just purchased a motorhome with 2 electric drop down bed and used for the first time and raised it up with pillows and duvet on and it blew a fuse.
The beds have built in spot lights on the underneath so when you raise it they come on when they hit the sensor so you know when to take your finger off the controls.
With duvet and pillows it struggles to reach sensor so kept finger on control to long hence that’s why fused blew.
I blew a fuse on our second outing trying to put it right on the ceiling, we also have lights underneath. Now we take it almost to the top and it’s fine for us. Husband is 6ft.1 and it’s good for him. The spotlights under the bed don’t work unless it is right at the top, not blowing a fuse again but to be honest we wouldn’t use them anyway, they are way too bright for our likingWe’ve just purchased a motorhome with 2 electric drop down bed and used for the first time and raised it up with pillows and duvet on and it blew a fuse.
The 5cm mattress topper squeezes the clearance on Brunhilde and we too have blown the fuse a couple of times! The underbed ceiling lights will work irrespective of the bed position [as I discovered when I left them on after lowering the bed, but I was able to see where the hoover was needed ...].I blew a fuse on our second outing trying to put it right on the ceiling, we also have lights underneath. Now we take it almost to the top and it’s fine for us. Husband is 6ft.1 and it’s good for him. The spotlights under the bed don’t work unless it is right at the top, not blowing a fuse again but to be honest we wouldn’t use them anyway, they are way too bright for our liking
That would a G740C wouldn't it?Duvet & pillows on ours plus ladder, no prob's.
Pilote P740c (A Class)
