Drop Down Bed Fuse Location Burstner 680G
BishBosh
None
Upgrades!!! of course
Drop Down Bed Fuse Location Burstner 680G - blown on mine but can't seem to find where it is, I've looked in the manual but it doesn't seem to be where it says (front left locker). I have also checked the main fuse box under the passenger seat and they are all okay...any help appreciated. Thanks
Lol...don't all reply at once!! Anyway I found the issue. For information and anyone that needs to know turns out it was me being a bit dim... The plug connector to the back of the bed key switch is in an area it can be easily dislodged. Having moved stuff around in the locker this is what happened. Luckily found this out after several hours dismantling the lockers to try and find a non existent fuse as well as checking every single fuse in the cab power box.
Here is a picture of the offending plug....
Reactions: maz
Nooooooo, please don’t think you were being ignored. Same van as yours and I’ve been looking for fuses since I saw your post. The manual is rubbish - all I can work out is that the bed fuse in the underseat fuse box is labelled Reserve 3. There might or might not be other fuses by the bed motor. I have nightmares about fuses blowing and not being able to find them! I have a mobile engineer doing other work on the van next week so I will ask him to locate any relevant fuses.
Re the plug connector on the back of the bed control panel, ours has a protective moulding over the back of it. See photo below:
Appreciate you posting back your findings. It’s always useful to learn the source of potential problems. (y)
Thanks Maz, that plastic cover looks good. I'll probably cobble something up to do the same. As for the fuse you are right it's Reserve 3 but as I said it wasn't blown!!! Called the dealer up about 10 times before I got a reply and apart from the fuse they were non the wiser too. Anyway at least if someone searches the interweb they will hopefully be brought here and see another option.
I have made quite a few personal changes to mine these last few weeks and will be posting them up on my thread here.... Incoming Thread
Reactions: maz
