Ducato from avatarwhat vehicle type / model
I think you need to explain that a bit better. Is it the cab heater or the motorhome heating? What panel are you talking about?Just started up my Motorhome , turned on heater only to find water coming from rear pipe work tried to take off inside panel to investigate more but had to turn off engine as unsure because dash in way ??
No such information on my phone....Ducato from avatar
nor my laptop?????No such information on my phone....
on laptop now and it says Ducato MH but not known which model.nor my laptop?????
yep got that now could not see it on my phone..Here’s a screenshot on my iPad.View attachment 596890
I take it the water's coming from the vehicle's cab heater up under the dash ? If so, it's a right mare of a job removing all the dash to get at the matrix. Some might advise throwing a bit of Radweld in to see if that sorts it, but there will be others on here decrying it, but if it's already broken.....?
It's there you just need to know how to find it.No such information on my phone....
Heater rubber hose either to or from the heater matrix unit.Just started up my Motorhome , turned on heater only to find water coming from rear pipe work tried to take off inside panel to investigate more but had to turn off engine as unsure because dash in way ??
Old fiat Ducato 1992 model ,4 berth , started up ,,, and put heater on ,,, water started to come out behind a plastic cover underneath housing the fan,, put my arm up underneath following a rubber hose as far as could get water running down ? Turned off heater and engine water stopped after a few minutes ,, re-started and it did the same so just turned off and left it ….Just started up my Motorhome , turned on heater only to find water coming from rear pipe work tried to take off inside panel to investigate more but had to turn off engine as unsure because dash in way ??
If you hadn't, you need to rotate the phone to 'landscape'.yep got that now could not see it on my phone..
Sounds like a leaking/perished heater hose or perforated heater matrix.Old fiat Ducato 1992 model ,4 berth , started up ,,, and put heater on ,,, water started to come out behind a plastic cover underneath housing the fan,, put my arm up underneath following a rubber hose as far as could get water running down ? Turned off heater and engine water stopped after a few minutes ,, re-started and it did the same so just turned off and left it ….
Will get under and try to get a better look at pipes today .nothing wrong with a bit of rad weld.
if it started when the heater valve was operated then maybe the valve is leaking..
