Hi,
does anyone know how to remove these type of drawers thanks?
Hi. I'm trying to lift draw but it's bending and nearly snappingYep
Should be able to fully extend the drawer, then lift the front and you will hear a snap. Then pull it further forward to take it out.
To replace it, slide onto runners and push all the way back and it should lock again.
EDIT - Can also let you know how to adjust them, or release the drawer front if needed.
Have you fully extended the drawer? It should release quite easily.
Just had a quick search on YouTube - this is the same type of drawer:
Genius. Worked a treat! Can't believe I didn't see that. Going to Specsavers today. Thank you kindly for help.The only other release I have ever seen on these types of drawers is a small release button under the runners. Blowing your image up, this could be it?
If that is a release, it looks like it needs pushing up into the frame gently, then slide the drawer forwards?
