Draught fridge.
Thornton Cleveleys
2004 Bessacarr E735
3 years
We've a hell of a draught coming through back of fridge. I've removed fridge and the foam sealing it has disintegrated.
What's the best stuff to use to reseal it please?
Thanks Trevor.
I've had a look on the other site but because I'm not a paid up member I can't see images.
How good is your memory? Can you remember what foam you used and where you got it from?
Cheers Tom.
Edit. Joined site and had a look at images.
I built up layers of neoprene rubber to the correct thickness, bit of work but well worth it. Fridge is draught free and absolutely solid in its housing.
Thanks Trevor.
Cheers Tom.
It was from memory, 2.5cm wide x 1cm thick.
It actually came as packaging in an Aldi boiler I bought .
Hopefully all done. Got some self adhesive foam from Screwfix.
Need some windy weather to try it.
Thanks for the advice.
