Draining water system down for winter
Discussion in 'Top Tips & Tricks' started by ramsthom, Oct 3, 2018.
  1. ramsthom
    ramsthom Funster
    Nov 23, 2011
    266
    durham
    Ratings:
    +202
    Don't know if this has been mentioned before and I know its a tad early but I picked up this tip to help clear the hot and cold water pipes when preparing for the colder weather. Drain down as usual and using an inflated balloon attach it to each tap and let the balloon deflate hopefully blowing any residual water out of the tap and lines. Tried it last year and it worked ok.
    • Informative Informative x 9
    • Nice One! Nice One! x 5
    • Like it Like it x 4
  2. namwaldog
    namwaldog Funster
    Jan 2, 2015
    1,155
    Cumbria
    Ratings:
    +3,338
    I wonder if you filled the balloons with Helium, it would make the pipes squeaky clean ?:whistle::whistle:
    • Funny Funny x 20
    • Love it Love it x 2
    • Like it Like it x 1
  3. peterc10
    peterc10 Funster
    Jul 5, 2013
    6,798
    Tunbridge Wells
    Ratings:
    +9,207
    Don't be silly, but it would reduce the weight
    • Funny Funny x 3
    • Useful Useful x 1
  4. Wildbill
    Wildbill Funster
    Nov 18, 2011
    9,818
    Ratings:
    +27,492
    I just blow Down the shower hose to clear most of the water don't know if I get it all out but never had a problem
    Bill
    • Funny Funny x 1
  5. hymerman
    hymerman Funster
    Oct 7, 2011
    75
    hereford
    Ratings:
    +78
    Also leave all the taps open , then if any residual water does freeze it can expand along the pipe instead of splitting it, worked for me for a number of years.
    • Nice One! Nice One! x 1
  6. hymerman
    hymerman Funster
    Oct 7, 2011
    75
    hereford
    Ratings:
    +78
    Forgot to say but leave taps open in mid position to cover both hot and cold feeds.
  7. Yorick
    Yorick Funster
    Oct 1, 2013
    5,532
    Lanzarote
    Ratings:
    +14,412
    Open all the taps and go for a short drive :)
  8. daveandsan
    daveandsan Funster
    Dec 10, 2013
    2,610
    South Staffs
    Ratings:
    +8,752
    I just attach the compressor to the shower hose, just make sure the other taps are open. :)
  9. Delboyarapaho
    Delboyarapaho Funster Life Member
    Dec 17, 2013
    194
    Herts UK
    Ratings:
    +148
    I think you might just have them laughing like a drain :)
    • Funny Funny x 1
  10. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    7,508
    Eastbourne East Sussex
    Ratings:
    +6,580
    I also just blow down the shower hose. Taps open and the shower head on the floor of the shower so any water can drain out. Grey tank empty and the drain tap left open.
    I did have a problem last year though as heading to Spain in February the drain tap froze open so I was an involuntary grey waste dribbler for a day till it thawed.
    Leaving it open helps to prevent smells as the anaerobic bugs responsible for bad tank smells don't like fresh air.
    • Thanks Thanks x 1
  11. Pausim
    Pausim Funster
    May 7, 2016
    1,166
    Poole, Dorset
    Ratings:
    +1,533
    I fitted a Floe device and was very surprised how much more water it purged from the system after the normal drain down. The inflated balloon probably achieves much the same and would be cheaper.
  12. bigalw35
    bigalw35 Funster
    Oct 13, 2016
    335
    Grays - Essex - UK
    Ratings:
    +387
    So what is a floe device ?
  13. Pausim
    Pausim Funster
    May 7, 2016
    1,166
    Poole, Dorset
    Ratings:
    +1,533
    Floe make devices to help drain down. My version allows you to connect a tyre pump to the system but there is a version that includes a compressor. I found it on the internet.
  14. tonyidle
    tonyidle Funster
    Aug 6, 2013
    6,835
    Kendal, Cumbria
    Ratings:
    +9,507
    I keep the van at 5 degrees or so all Winter.
  15. two
    two Funster
    Aug 4, 2011
    3,083
    West Midlands
    Ratings:
    +3,220
    I wonder how many people do nothing, other than drain down, and get away with it?
  16. bigalw35
    bigalw35 Funster
    Oct 13, 2016
    335
    Grays - Essex - UK
    Ratings:
    +387
    at what cost ?, November till March ??
  17. tonyidle
    tonyidle Funster
    Aug 6, 2013
    6,835
    Kendal, Cumbria
    Ratings:
    +9,507
    No idea but l use a 600w greenhouse heater on frost setting. I've been doing it since our caravanning days. My off-season is mid-November to the first week in March minus a week just after New Year. There aren't too many nights during a 'normal' Winter where the temperature is below 5 deg C.
  18. Rockcrawler
    Rockcrawler Funster
    Apr 17, 2017
    1,059
    Ferring
    Ratings:
    +4,408
    Sounds like a great idea except mine has a one way valve fitted so not quite sure how I will get all the water out of the pipes
  19. Yorick
    Yorick Funster
    Oct 1, 2013
    5,532
    Lanzarote
    Ratings:
    +14,412
    My van is 21c all winter :)
    • Funny Funny x 1
  20. Pausim
    Pausim Funster
    May 7, 2016
    1,166
    Poole, Dorset
    Ratings:
    +1,533
    Drained down yesterday, for the first time since moving to a new storage site. My new parking position leaves the moho slightly tail down and this made a big difference to how much water was left in the water heater after the normal drain down.
    Having let the water fully run out of the drains I followed my normal procedure and attached my tyre compressor to the Floe connector. The first indication that something was different was the sound of bubbles blowing through the water heater but no more water coming from the drain. Having closed the hot water drain I then worked through the system tap by tap. Having removed the extra litre or so that normally lies hidden in the pipes I found that there was hot water flowing out of the shower tap in the cold position. Subsequently I drained about 2 litres of hot water via the cold. My theory is that the cold inlet to the hot water heater lies at the back of the unit but the normal drain does not and that the air pressure in the sytem pushed the water back out through the cold feed.
    I am satisfied that I have now drained the system properly but was very surprised by how much difference being just a little bit off level made. Not something I previously paid much attention to.
    • Thanks Thanks x 1
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
