JockandRita
- Aug 2, 2007
- 11,462
- 150,080
- N+B Flair 8000i
- Since May 05 (Ex Tuggers).
Flair 8000i 2006
Although I was warned of the slow drain down by the previous owner, draining down a full water tank after sterilising the system, took an hour and twenty minutes, (yes I actually timed it ). The hot and cold water lines took no time at all, in comparison. I had the taps open on the cold side, and I even opened the tank cap, to relieve any possibility of a vacuum forming. No joy.
I have blown back using lung pressure, then tried compressed air. I have back flushed with mains tap pressure, hoping to maybe dislodge a blockage of some kind. So far, no joy with increasing the pitiful flow.
The pipework is 15mm speedfit, so a kink in the line is highly unlikely.
Has anyone experienced the same problem, and if so, what was your solution please?
Thanks in advance,
Jock.
Thanks in advance,
Jock.
